I know your excited about this project but calm down and quit trying to make this harder than it is.
Measure the size of area you want to soundproof. Buy that amount of sq footage of R-11 or R-19. Personally I would get R-11 becuase of the cost and I think it would do what you need. It is also easier to install in a tight place.
Purchase in 2x4 pcs if cost effective because that will be the easiest to install.
Starting on one end of the room start laying the insulation on top of the ceiling tile removing only the ones you need too, again to make this easiest as possible.
You may want to use a pc. of tape to mark the tile near pipe locations for later IF NEEDED. Chances are this is going to make such a difference you will be satisfied.
If you need to insulate the pipes, I suppose the black flex insulation would do. Forget the expanding foam that stuff messy and expensive.
Believe me you want to simplfy this process you are going to itch for a week and then the following week you are going to think you are still itching.
Wear a long sleeve shirt, put baby power on your exposed skin, wear a mask if you are a health nut, take a cold shower when you are done( closed pores keeps the fiberglass out)
If money is no object use the R-19. Good luck and post back the results
edited to add, you will lose a lot of sound proofing thru HVAC ductwork, so trying to soundproof this area is impossible, so you do the best you can, live with the rest.
