I'd stick with the SVS unless you want to build it yourself.
There was a nice review on a sub on avsforum front page yesterday that might be for you.
What about an HSU ULS-15?
http://www.hsuresearch.com/products/uls-15.html
They are currently running a Fall Sale and you can get a single 15 for $1075. Pretty hard to beat at that price.
Also considering this one. Is it pretty much a wash between this hsu and the svs?
get 2 of those HSU's and call it a day!
I'm not going to try to convince you to buy a ported sub, but this is an extremely narrow (and usually wrong) view.Ported = boomy + sloppy.
The Hsu subs lack a DSP. More boom for the buck, but the lack of DSP will make it a less accurate. It's a trade off.
What are you using the sub for, music, movies, both? If both, what is the ratio?
No real difference between a port and a passive radiator, and both can be tuned to be tight or boomy depending on the same parameters as a sealed box.
Dr Hsu understands bass and knows how to make a great sub, I would have no hesitation to recommend his products.
What are you going to do with the old Vel, I'm in Orange as well.
you need to listen to better ported subs then because that statement is not really true
anyway
http://www.powersoundaudio.com/products/xs30se
anyway
