xtreme2k, you might be correct, though I'm not totally sure.. I DO know you can run Gigabit ethernet over Cat5e though.
well it depends, if you are going for 100Mbps Full duplex (BTW that's megaBITS per second) then any old card that supports full duplex and 100Mbps would work, though some would suggest 3Com and Intel cards over others (quality issues?).
the CAT-5 cable costs little to nothing, though if you are going to run 40 feet, I think you'll be hard pressed to find a 40 foot patch cord.
You might have to resort to running cable through the walls, terminating them, and installing wall jacks, and then buying 2 patch cords (this method would comply with the standards set for reasons such as fire safety etc), one to plug into each wall jack..
