Best Motor Oil?
Status
Not open for further replies.
Castiel
1,772
Got into a discussion with a guy at work today and he thinks Mobil 1 is the best where i believe RP is. Which is the best?
Closed due to necro-bump.
Zenmervolt - AnandTech Moderator
thescreensavers
9,916
Lol, there is no "BEST Oil" go do some UOA's if you want numbers to argue about.
Edit: if you are talking about the same engine
reallyscrued
2,618
Bang for buck, probably Pennzoil. Look at some used oil analysis forums for more info.
thescreensavers
9,916
How about Top 5 then? :biggrin:
What i'm thinking is
1. Amsoil
2. Royal Purple
3. Redline
No... There is no best oil, oil differs from engine to engine. One engine X oil can be the best, but in another B oil is better.
No such thing as "BEST OIL"
exdeath
13,679
10
Best at what? There is so much shit to oil it's not even funny.
If you're thinking about the GT-R, it's whatever Nissan tells you is the best :awe:
Any differences in the "best" oils are also mitigated by the fact that any enthusiast buying that kind of oil also changes it far earlier and more frequently than needed.
JechtShot
326
The synthetic oils you see on the store shelves are not true synthetics. Too many variables in determining "what is the best oil." German Castrol is a true synthetic oil from what i remember. You will learn a lot here:
http://www.bobistheoilguy.com/cms/
Eli
Super Moderator | Elite Member
8
1. Amsoil
2. Royal Purple
3. Redline
All of those companies make good oils. So does Pennzoil and Mobil1.
The only way to determine whether they're doing an adequate job with your specific engine, driving style, environmental conditions, etc.. is to have oil analysis done. Anything else is just a pure guess.
EightySix Four
5,122
52
There is an oil analysis tech that used to pop into the forum a lot. He always complained that RP ate up bearings and that Mobil 1 was not consistently weighted from batch to batch. I can't remember for the life of me what he recommended though.
I still use Mobil 1 and if I'm expecting especially aggressive driving, Amsoil with an earlier change.
Castiel
1,772
Hmm.. Maybe i'll try amsoil in the SRT. Its due for an oil change. All i've ever used in it is RP
jlee
48,518
224
IIRC Subaru engines don't like Royal Purple, and Mobil 1 5w30 breaks down quickly. I run Shell Rotella T6 5w40 in the Subaru and Mobil1 10w30 in the MR2.
Kaervak
8,460
If your car is under warranty, it's whatever the manual tells you. Out of warranty, whatever you want.
My personal choice in everything I have with an engine, Pennzoil yellow bottle conventional. And I mean everything with an engine. Both cars, weed eater, lawn mower, tiller, snow blower & wood chipper, they all get yellow bottle.
vshah
19,003
24
i've been using royal purple for a couple years...will be getting UOA at my next oil change.
KDKPSJ
3,288
58
I usually use UOA-confirmed oils from BITOG users for the cars I work on. For instance, for my G37, it would be Mobil 1 0w-40 (GT-R friendly, btw) and Pennozoil Platinum & Ultra 5w-30. For my brother's E90 325i, it would be BMW-LL01 certified, specifically, German Castrol and Mobil 1 0w-40.
Since Mobil 1 0w-40 works on both, I will probably stick with Mobil 1 0w-40 from now on for both :)
KDKPSJ
3,288
58
Noted. Thank you sir. I shall pay more close attention next time.
Yup, quite easy to find with those red words ---- as long as they carry 0W-30, which is only German Castrol exists in US. From my experience, Pepboys and Autozone carry it, while Advanced Auto Parts doesn't. Your local experience may vary :p
Elganja
2,143
24
i used to be a nut about amsoil... now I just use Mobile 1 since I can get it at costco
Zivic
3,505
38
I only use amsoil...partially because of the high zinc formulas.
mobil1 is not what it used to be and I wouldn't personally use it.
doesn't royal purple use moly in their formula? if so, I would never use it any of my motors.
Demo24
8,356
9
Mobil one has been accused of creating big issues in Subaru issues, spun bearings etc. I too also run 5w40, but probably not the best idea to do so in the winter. I switched back to some 5w-30 just for some peace of mind, when summer hits back to Rotella T6.
WackyDan
4,794
68
Screw Mobil 1. I was using their Mobile 1 Racing 4T for my bike. They went and changed the formulation, adding an SM rating to the mix.
Never changed the fucking bottle, only the ratings stamp on the back. Needless to say, that SM rating/formulation will cause some wet clutches to slip, and will require early replacement of the clutch.
Status
