Best method for removing thermal pad from HSF
For me there is this stuff called Sticker Shock you buy at auto stores. Wal-Mart might carry it aswell. You don't have to get that brand just any sticker/bumper sticker remover should work. Either way you spray a little on it to cover, wait a min and it just wipes off easily. Wal-Mart carries this stuff called goo-gone that can be found in the cleaning or probably automotive section that should work aswell. Just finish cleaning with Alcohol. Most recommend just using Alcohol but it is alot harder. Finger Nail Polish remover might do good for removing it quickly then clean good with alcohol.
