best memory for gamming machine
Eis
whats the best memory for around 300 for a 1gb for a 3400 64 on a msi neo platinum, need suggestions
Honestly, I think people get way to caught up on memory. For just about every application the timings don't do much. I spent a lot of money once on advanced timing memory and didn't see anything change. I am sure that in memory intensive situations it helps, but for gaming, I dont really think so. However, if you are planning on doing a little overclocking faster RAM (that is to say sticks rated to higher bus speeds) may be good idea. If you really wanna spend $300 on memory I would suggest Corsair XMS PC3700 2x512MB Pack. It goes for $285 on newegg and comes with neat lookin heat spreaders. You also can't loose with Corsair memory.
best memory ?
something that works at the speed you need it to at the price you want it at. for a few extra bucks, i tend to just get ram from crucial, and i recommend it to friends. great company, great service. prices and free shipping are in line with everyone else
Originally posted by: CraigRT
there are many good brands..
does the MSI site have a recommended memory list?
Corsair
Mushkin
Kingston
etc.
look up to what your mobo manufacturer suggestions for compatibility. it's only in overclocking that you need higher-rated frequency, timings, etc. if not overclocking then, any of the above that is compatible with your mobo.
other good personal experiences: geil, infineon, micron, samsung.
