here -
Pros: Twist those knobs clockwise (unlocked). Line up pins with holes in motherboard. Push the top left at the same time as bottom right.
Make sure you push the metal leg when connecting into the mobo. When the bottom snaps in (will click), push the head of the plastic pin down all the way, and then twist counter-clockwise to lock.
Cons: ONLY difficult to install if you dont realize what is going on
Other Thoughts: It really helps if you toy with the plastic pins before installing.
Turn clockwise to unlock. Note that you can push the pin down into itself, and pull it back up with some force. Now, push the pin completely down and then twist COUNTER-CLOCKWISE. The pin now cannot be lifted back up.
This may help. Just remember, leave it unlocked, click it into the motherboard by pushing the METAL LEGS. Then snap down the pins and lock them.
