CallMeJoe
When you're used to 27" at 10', 42" seems large.42" too small for 10 foot..that is far.
If he was uncomfortable sitting 5' away from the TV, then it was indeed too close - for him. Not everyone wants full immersion video.Is it a true 1080p 50" tv? It isnt too close at all. If it were too close projectors would force you to sit in the next room back😛
I would be hard pressed to call a 50" TV from 10' away "small".Then it is just your taste because the recommendations are based on the eyes ability to resolve detail at a distance and the amount of the visual field filled by the screen. I just don't see the point of buying a tv just to sit so far away that it becomes small again.
THX recommendations are often irrelevant in the real world, and sometimes quite impractical. Not everyone wants to sit 4-5' from a TV. For those who want to sit further back, not everyone wants a 60" TV taking over their living room either. And even if someone might want a 60" TV, that same someone might not want to spend thousands of $ on one, when a $600 TV will suffice.Well its fine in that you can see it. It is however far from optimal, from that distance the detail of 1080p is wasted, and the tv is so small in your visual field it is not immersive for films.
http://myhometheater.homestead.com/viewingdistancecalculator.html
42"
Maximum THX viewing distance 6.6ft
Recommended THX viewing distance 4.7ft
so as u can see, 42" is far from optimal size.
Really, for "optimal" you need a dedicated light controlled home theatre, with a popcorn machine in the back, and a couple of servants serving up drinks.So while not tiny, at 10 feet you can hardly call it optimal, esp for bluray.
I could never find servants anything but obtrusive.Really, for "optimal" you need a dedicated light controlled home theatre, with a popcorn machine in the back, and a couple of servants serving up drinks.
Have you actually stood back 10 feet from a 50"? Sure up close its big. At 10 feet the impression is rather diminished. Add any letterboxing and it gets a whole lot smaller very fast. Sure its big compared to a 27" crt, but anything is. Even worse is those old crts stuck out from the wall 2.5-3.5 feet, whereas the flat panels tend to be that much further back. So while not tiny, at 10 feet you can hardly call it optimal, esp for bluray.
Well just in case anybody cares. The Samsung F5300 or the LG6600 is the only game in town anymore. You can pony up for the Samsung 8500 if you got the cash or downgrade to a Samsung 4500 768P set.
I wouldn't even consider an LG Plasma. They aren't even close to the Samsung.
I'd go with a good Samsung LED before an LG Plasma, personally. Unless you're shopping "price only".
What are you basing this statement off of?
i sat 10 feet from a 50 for 3 years and it was fine
TV down stairs is a 55 and that main seat is 14 feet from it also fine
when i had the 50 i actually moved a chair inito the THX recommended distance and it was far to fing close to the TV, no one sits that close to their TVs
