bob4432
- Sep 6, 2003
- 11,727
- 46
- 91
Originally posted by: Bobthelost
Nope, haven't used SCSI since the old macs switched to IDE drives. I do hang around SPCR too much, which tends to make me shudder at the thought of 15KRMP drives not to mention the heat that they give off. Look at the power draw for them! Might try it some day if i stay single, otherwise the GF will get jealous again.
A 36Gb SCSI drive might be a good middle ground, but i think that the RaptorII is comparable for desktop use, if not better, and it's probably a bit cheaper. Don't have the stats to prove either way.
i think you are going off the info from the past. although i haven't gone 15k yet, i have always used passive cooling on my hdds, regardless of speed. so there is always a 70-120mm fan blowing on my hdds, depending on which case they are in. the 10k fujitsu runs about the same temp as my 7.2k, but i will admit some of the older ones were quite warm, as were the old 7.2k one.
for idle power -
maxtor 15kII - 36GB = 7W, 74GB = 8.4W, 147GB = 13W
raptor 150 - 9W
i go the fastest seek times i can get for the $$ i have at that time and put my os/apps and games on it. this is what i am most concerned about, seek times and that is why i am looking into the 15k arena. going from 7.2krpm to 10k was a noticeable difference, so i assume going to 15 would be a noticeable difference over 10k.
the way i look at it is that although i will game, my computer is used for everything from gaming to photoshopping to video creation and encoding of video and audio. i have many programs, and all programs haver numerous files that have to be loaded into ram when the program is started. it takes time for the hdd to locate the desired file location, so the faster the seek time, the faster my overall computing experience will be. a distant second in importance would be str, but most of my encoding is done on my larger hdd anyway and when encoding i am usually cpu limited.
lastly, there is a small cpu advantage when using scsi, although not a big deal anymore.
you may want to pick one of the newer (probably just 1gen old at most) 10-15k hdd up and pick up a lsiu160 or adpatec 19160, 29160 or 39160 just to see. they can be had for decent prices(for scsi at least, not trying to compare scsi and sata/pata price per GB)
no doubt the raptorII is a good drive, but i think @ $300 it is too high. if it were $170-$200 i think wd would sell the hell out of them.
