imported_burningrave101
I stick with the big three when i'm looking at cases: Lian-Li, Cooler Master, and SilverStone. You can't go wrong with ither of them and each one has something to offer over the other. The SilverStone cases tend to be the most expensive but Lian-Li is keeping up there with their new V-series cases which i dont like very much.
If you dont need an absolute ton of room then i would suggest a Cooler Master Praetorian or Wavemaster or possibly look at one of the SilverStone cases.
I've had a Thermaltake Tsunami and the quality sucks compared to what you'll get from these three.
I would suggest trying to find a case that uses 120mm fans instead of 80mm because it improves the airflow alot and the noise level is reduced.
