Originally posted by: aigomorla
Originally posted by: CP5670
The Armor looks good too but as far as I can tell, doesn't support dual power supplies and has those doors (or whatever they are). I personally hate doors on cases. 😛 Are they removable?
That would be quite convenient if you could just use the Armor fan panel, although they would need to be exactly the same size for that to work. Thanks for the info.
ummm as i said i think the pannal is almost identical. I have both cases, and honestly i dont see the need for a dual PSU layout. My TJ-07 has it, but i dont use it. I dont think u'll ever need a PSU greater then 750W unless ur quading sli or 2 8800GTX on a Extreme platform processor. And as i said, if you want that 25cm fan, that maybe your cheapest options because i cant think of another place u can go pick up a fan that big on a 12VDC setting.
And yes u can remove the doors if you want, but i like them. They have saved my front bay from collision of stuff. And the doors are really really strong. IT would take some effort to actually bend them.
