BTW,
If you guys need to buy a magnifier for your GBA SP, get the
Lynx one over the Pelican. (Magnifiers are great b/c they really add a couple inches to the screen size!
Lynx's has a much bigger, thicker, higher quality lens than Pelican's. FOr maginification, I know the lens must be curved, but not enough to render the screen in an ineffective manner. Their lens has the "just right" factor.
The Pelican generally makes great products, but their SP magnifier is a
turd. Cheap construction; small lens; it can damage the grooves on the SP screen; and lens is toooo curved--the screen appears very curved. I got a headache from it. :Q
BTW, with the Lynx lens, don't throw the box away. I had to return one b/c after using it the stress of the lens being pulled out caused hairline scratches on the lens. The 2nd Lynx lens does *not* have this problem after using and purposely stressing it to find hairline scrtaches. Rock solid so far.
BTW, SPlinter Cell is coming out this week for the SP, I believe.
