best fan controller for Tornado 92mm?
L1FE
I recently bought a frozencpu.com PMW fan controller to try to control the jet engine known as my Vantec Tornado. However, after setting everything up, nothing has changed! I'm wondering if it's the fan, the controller, or whether I'm just completely retarded and can't put the correct male connectors to the correct female receptors. What fan controllers work for your Tornado 92mm??
Vantec Nexus 305 fan Controller
AMD Athlon XP T-Bred B DLT3C 1700+ @ 2.3GHZ (1.775v) 400FSB = 3200+
Abit NF7-S V.2 (nForce2-U400)
Corsair TwinX XMS 3200LL 512MB @ 2-3-2-6 (2.6v)
Sapphire Radeon 9500 Pro 128MB
Antec TrueBlue 480W
Thermalright SLK-947U with 92mm Vantec Tornado @2800RPM
Maxtor 91531U3 15GB
2x Western Digital WD400BB 40GB serials
Antec PlusView 1000AMG
Cambridge SoundWorks MegaWorks THX 550 5.1
I would say any 12V compatible fan controller. The Nexus 305 comes with 2 cold cathode lights, so it makes a good combination. If you don't want CC lights, I would go for the standard vantec nexus fan controller.
Be sure that you haven't connected your fan to both your controller AND your PSU cable as this would void the function of your fan controller!
I connected the 3 pin connectors to the controller and the 4-pin molex also to the controller...didn't work 🙁 Oh well...I'll look in the Vantec 😀
try to see if your PSU has a power fan plug, if so plug the tornado on the PSU then the controller.
Abit NF7-S V.2 (nForce2 U 400)
Antec TrueBlue 480W
Maxtor 91531U3 15GB
Already did that, doesn't work 😛...the problem isn't starting the fan, so much as getting the rpms down 🙁
I know that, but some psu have fan power plugs, and for the tornado you need to plug it in so that when you use your controller you can lower the RPMs down
Antec TrueBlue 480W
Maxtor 91531U3 15GB
