You need multiple deterrents.
-Hidden fuel pump kill switch (easy to install yourself... multiple ones are better... you can hide it somewhere or even wire it to buttons on the dash)
-Brake lock (same as clutch lock just put it on the brake so the car won't go into gear)
-Fake blinking light on dashboard (they sell these)
-LoJack sticker
Glad you like the first idea, but you should look into the others as well! Having multiple deterrents is much better.
It's easy to install a kill switch on your own, provided you have the right tools. My technical experience doesn't extend much beyond yours, and I was able to install one in my car with a wire crimping kit (soldering + heatshrink wrap is the best way though) and a rocker switch bought from a local auto parts store. You should look up tutorials on the internet... they will walk you through it. What I did was locate the car's ECU, probably somewhere under the passenger side dash. There are a bunch of wires coming off it, one of which is the fuel pump wire. Ignition wire works too. All you do is cut this wire, wire a switch into it, then hide it. The switch you buy will have two connections. Each side of the wire that you cut goes into one of the connections.
dont forget scorpions. never leave out the scorpions.
No need for a switch, just pull the fuel pump/injector or ignition fuse![]()
If it's at least new enough to have a PATS system (RFID in key) they aren't taking it without a flatbed.
Honestly, what you did was to help keep your car from being stolen. And that is just fine. But odds are it wasn't likely to be stolen anyway.
What you probably really should do is get a blinking LED light. One of those will keep the car from being broken into. Which, is MUCH more likely to happen vs. being stolen.
Now think about this: Do you want to find your car with the window broken or the door handle / lock ripped out, but the car not stolen? Would that justify the price of the kill switch? Yes. Or, would you rather the guy see the blinking light, assume it really has an alarm and move onto the next car (with no blinking light) and never break your window or damage your car in the first place?
