Best case in terms of cooling for SLI?
kilovolt3
I want to use an A64 3800+ and 2x 6800GT's in SLI mode with the PC Power and Cooling 510 SLI power supply. What would be a good case to use for this setup that will keep the system nice and cool?
The CoolerMaster Stacker comes to mind, but just about any decent tower (not mini or mid-tower) case with decent airflow should get the job done.
I think I like Coolermaster stacker better since you can add more fans to it. But it says that the type is ATX extended and the mobo that I am getting is an ATX mobo. I was going to get the MSI K8N Neo4 Platinum SLI mobo. Would this mobo fit?
The Aspire Navigator is a fantastic case for cooling as is the Thermaltake Tsunami case. Plus, they look really cool. Lian-Li cases are also nice if they are modded up good.
E-ATX (extended) generally are server boards. ATX will work fine. The coolermaster case also is switchable to the upcoming BTX form factor. So it's set for longevity as well.
http://www.coolermaster.com/index.php?L...TC-T01&other_title=STC-T01CM%20Stacker
in that silverstone case above how do you cool the hard drives or video card?.... the widntunnel isnt to smart sometimes....
you get a expansion slot fan and you have an 80mm intake and use that as an exhaust, and if you feel like modding you can make a side fan and a blow hole
I just got a Chieftec Ultra Dragon and I love it. Lots of room inside, removable hardrive bays, and improved cooling a fair amount over my Aspire X-Dreamer II case. With the computer in my sig at stock vcore I get idle temps of ~25C and load of ~36C. That's with the cpu fan spinning at 800rpm. I need to figure out better cooling for my cards but they still aren't bad at 62C top/55C bottom (idle). The bottom card is more accurate considering the driver temp bug affecting the top card.
The case runs around $70-100 depeding on the rebates going on. Here is a link to the site where I got mine.
