3DVagabond
- Aug 10, 2009
- 11,951
- 204
- 106
99.999% yes
If it doesnt work you can chose presets again
If you dont raise voltage its safe. Using the amd tool is then safe. Remember to go to +20% for the power when oc.
Have fun !
^^^This^^^
Also, get your max O/C on the core B4 you start raising the mem clocks. A lot of people try adjusting them both at the same time and don't know what's causing the instabilities when the occur.
