Originally posted by: Eman1
Tenoc,
Why would you say the crucial is lelele? It is clocked at 250mhz core and has 6ns memory (like most 128mb versions).
Just curious. This seems to be spec for most 8500le 128mb cards. Am I missing something?
Eman
Simply put...
R8500: 275/275
Soyo R8500: 290/290
The vast majority of 8500LE's: 250/250.
The above is also ATi's specification for the R8500LE core.
The much maligned R8500's nicknamed the R7500'LELE': 230/230 or 250/200.
The slowest Radeon 8500 available....
The All In Wonder R8500DV: 230/190.
Then of course you have Crucial.... 250/166.
They've strangled the 8500LE with bandwdith limitations to the point wherein it's typically getting beaten out by the GF4 MX440 in most cases..
The R9000Pro decisively outperforms it.
It's sad enough that even the R8500DV manages to outperform it.
This at a price that manages to be higher then virtually all other R8500LE's.
Room to overclock the memory? Not realy.
Even most of the sub-par 8500LE's at least give you 4ns DDR SDRAM in TSOP packaging.
A far cry from the BGA packaged 3.3ns DDR you can find on the best R8500's but not too bad.
Crucial? 6ns DDR, TSOP packaged. Just enough to much their stock clock of 166MHz DDR and leave you with little room to overclock.
In short, I'd be inclined to say... Crucial has made a mockery of the R8500.
May as well buy an R9000 non-Pro for close to half the price given the performance your getting.
