Best C2D mobo for $100-$150?
Sniper82
16,517
I might be getting some extra money in a month or so and I want to start looking into a C2D setup. I only want to spend $100-$150 for the motherboard. I will be o/cing within a month or two of buying(once the newness wears off). So the board must o/c well.
So whats the most talked about C2D motherboard in this price range(if any)? I'll probably get the e6300.
BTW is a 480watt 24pin Dual Rail Enermax enough power nowadays to run a C2D setup(non SLI/Crossfire)
Vette73
21,503
9
Yep I have the S3 and its a great board. I went to gigabyte after using Asus. The gigabyte ran better and overclocked better.
you2
6,890
1,965
Which asus marlin. Not all asus created equal.
I've been looking at the p5b-e, d3 and foxconn. Not sure which I will go with but the highlights:
has most features ($154) (also new design - after the earlier asus p965 boards), d3 ($144) early board very popular, foxconn (late design - well regarded - $102) - hte p5b-e has intel raid, firewire, jmb raid and (better or different sound chip), the d3s has jmb raid (no firewire), the foxconn has no raid but has e-sata.
cmdrdredd
27,052
357
The P5B-E will achieve higher overclocks than the DS3. More people have reached 500+FSB on the P5B than the DS3.
BlingBlingArsch
1,249
good to know if true, can u say something about the influence of the C2 stepping?
