Originally posted by: OREOSpeedwagon
Bitcomet
:thumbsup:
Bitcomet
Originally posted by: Anubis
Azureus > *
Originally posted by: Goosemaster
abc
Azureus > *
Simple and powerful while not being a resource hogBitcomet
Originally posted by: Dragnov
ABC
Azureus > *
Azureus > *
Azureus > *
If you money toblow on fast computers,minimum system requirement: 3ghz, 1gb ram. 64mb agp 8x video card. it's very sluggish on my computer. here at 2ghz. 🙁
azureus is java based and so it's inefficient as a client. too many feature I don't need, configuration confusing.
ABC
Azureus > *
humm it runs fine on a 700 mhz celeron with 384 megs of ram, a TNT2 GFX card running win 2k
ive never had it crash on me wither so IDK what that other poster is talking about
Azureus > *
the torrent you are working with are small ranges from a few meg to 700mb?
try it with 5gb to 32gb torrent, you will see a serious drain on your cpu and memory. the reason why most use azureus is that java is popular and so they think it's good. I have compare it to bitcomet, bittornado, it does not let you download faster, resume faster or connect to more users.
I download as many as 10 5gb torrent all at the same time while the computer uses only about 10-15 percent on 2ghz machine, 256mb of ram. the key is convenient and fast. I find that if you leech from numberous torrent simataneously, your overall download speed is much better then to download from 1 or 2 torrent using bittornado.
I did not find that sun java works better then ms java. sun takes up 120mb of disk space, ms java only 10mb!
Originally posted by: csyberblue
I use azureus currently.
One thing that I like about it is that it gives me a lot of stats. I think bittorrent is an interesting program, and I like how in azureus it shows me graphs of the users connected to me and gives me what countries they are from. Do any other clients give as much stats as azureus does?
you really care what country they are from? you gonna meet them in person? 😀
stats mean nothing, if all it does is try to impress you with graphs. what really matters is the number of seeds, peers, your download speed.
