Nifty Gpu vram info check tool - MemoryInfo+ 🙂
Doesn't let me choose the card. Shows what I knew already though, that my Sapphire 7970 was Hynix (the bios only shows support for hynix anyways)
How do I choose the card for the utility?
This guide has been available for months over at OCN and this is nothing more than a copy and paste job with more pictures added. The only question is whether this is the original author or not...
Read the last sentence in his introduction.
It's his guide.That validates what exactly? It would be proof if it were listed on the OCN thread stating that the guide was posted here but stating the source in the OP does not validate the OPs identity. 😵
That. is. AWESOME!Nifty Gpu vram info check tool - MemoryInfo+ 🙂
160 x 1.1 = 176
190 x 1.1 = 209
The core doesn't run directly off the 12v you dolt 😀.
If you care so much, you could go to that forum and ask that poster if he's the same person.
Apparently a guy called Belial88@Anandtech is trying to take credit for my work, using his name on the guide instead of mine.
LOL, I'm leaving that one alone. 🙄
Can someone elaborate bit more on using this tool?Nifty Gpu vram info check tool - MemoryInfo+ 🙂
Slomo4shO, You can't be serious.
t would be very displeasing to release a GPU that throttles all the time. But yes it only throttles above 90C as a safety feature to keep the GPU from getting any hotter. And congrats on the new Purchase.
I run it and get nothing but empty info boxes. (win 8.1)
I'm running dual Sapphire 7950's and already know what my memory is because I checked when I had the heatsinks off.
Just wanted to see how this tool works.
Anyway, mine are....
Elpida - 1.6v
W2032BBBG
-50 -F
123906A1T08
(-50 -f means 5ghz memory chips)
As some suspect, I think some of the Sapphire 2L's use Elpida -60 -F 6ghz memory, since some 2L's overclock really well on the Elpida memory.
Ive seen screenshots of the -60 -F chips on a Sapphire somewhere and of course cannot remember where or I'd post a link.
By the way let me remind people, that I've edited the guide to reflect the following:
The +50% power limit fix on 7950s is mandatory. With no power limit fix, or even +20%, your card will run the majority of the time at ~500mhz, NOT 1ghz, 1200mhz, etc. You will see about a 80-120% increase in FPS by doing the +50% power limit fix. These cards are HEAVILY throttled with the stock power tune. Literally, running 900mhz@+50% Power tune is better than 1200mhz@0 power tune. This is because these cards throttle themselves at stock settings, so if you overclock - which consumes more power - your cards will throttle even more. As in, you will on average run at about 500-700mhz despite an overclock of 1200.
ANY 7950 model, including the aftermarket models, WILL HIT over 80* on 100% fan speed at just a stock settings of 925mhz@1.25v (ie boost setting). 1.25v is really only achievable on water.
Where do you get this crap? Stop posting this misinformation.
I am not seeing the above throttling ( using Trixx) in the two games I have on my computer now and playing using +20%. I just tested a level in each game after reading the above just now.
Crysis 3 below (per in gaming graph screenshots on 2nd monitor)) settings 1100/1500 @ I saw a couple small quick drops in clocks for seconds but that was it (a second or 2) in C3 otherwise a steady 1100/1500
BF4 below stock settings 925/1250 I didn't see any clock drop in BF4.
Glad I wasn't the only one scratching their head. My 7950 can run overclocked at +20% power setting without throttling.
Also just wanted to mention below (7950 Boost) my temps in CFX running Crysis 3, stock clocks, stock fan profile and closed mid-tower case w/3 120mm.
GPU 1 67-71c
GPU 2 runs about 5c lower per above card temps.
Boost varies from card to make to revision. What clocks, what voltages (i assume 1.25v but not all boost are 1.25v)? What fan speed? This information doesn't really tell us much. Did you use the +50% power limit? What model are you even using?
People generally dont use games as benchmarks. They use benchmarks are benchmarks. Run a stress test for a heat test comparison, game to game varies so much and games, relatively, do not push hardware at all. You'll likely see a good +20*C with +50% power limit and on a proper stress test, whatever card that is.
I'm not sure how you definitively state that, because that's not true. If by 'without throttling' you mean you dont get noticeable throttling in a game that the 7950 manhandles easily and you wouldn't know throttling if it happened anyways, then sure.
You don't always need a shim for the "red mod". My Powercolor 7950 Boost worked fine with no shim, just some Fujipoly Premium thermal pad in-between the die and the Thermaltake Water 2.0 Pro copper block. It's zip-tied on. Also get zero throttling during Heaven with +20% power limit and saw no boost from going higher. YMMV.
It didn't throttle when bitcoin mining so it wasn't just with "manhandled" games. Perhaps folding@home projects? Are they closer to power ramping programs like Furmark and OCCT than the GPU bitcoin client was?
Sapphire 3L Boost
Stock Voltage (1.25v)
Stock Clocks 925/1250
Stock Fan Profile
+20
Just for reference below are 2 previous BM's I ran awhile back per UH 4 Extreme benchmarks @ 1150/1600 +20. I also ran a UH 4.0 Extreme BM (stock settings per above) along with MSI AB opened on my second monitor to monitor it during the test yesterday after reading your post along with the gaming test yesterday. I did not see any throttling in the clocks in MSI AB while monitoring it on the second monitor during the whole test it stayed at 925/1250 though out that test in UH 4.0 Extreme yesterday.
http://forums.anandtech.com/showthread.php?t=2341362&page=2
http://forums.anandtech.com/showthread.php?t=2341362&page=18
