Been using my TT Tsunami for a week...
crap, i just BOUGHT this off of zipzoomfly :roll:
i guess i'll just buy some quieter fans
Cancel order + buy a Centurion 5 = profit.
psh, FANBOY
I think it's fairly obvious that that post was made with tongue planted firmly in cheek. Despite that:
The point was, if you're worried about the case, cancel the order and buy something else. I can vouch that the Centurion 5 has made me quite happy and is reasonably priced, but depending on how much you're willing to spend, there's a variety of cases from a variety of manufacturers that are great quality. In the under $100 range, look at CoolerMaster and Antec. If you're willing to go up to $150 - $200, there are a lot of great options by Lian-Li and Silverstone.
Give them a look. The last thing you want to do is buy something you'll be dissatisfied with.
well i've been looking at the tsunami for about 4 months now (i even went to a store and LOOKED at it, but they wouldnt let me test the fans)
im just sick to my stomach because through AT forums, people say that my case, psu, mobo, and hdd selections have been bad . . .
Eh, you'll never satisfy everyone 100%. However, if EVERYONE is suggesting you go with other things, you might want to consider their advice...
I mean, the Tsunami isn't a bad case by any stretch of the imagination, I just think an Antec or CoolerMaster model probably gives better performance and build quality for the dollar.
psh, FANBOY
well i have a few people (with high post counts and good experience in computers) saying :
1. dont get a TT, get a CM or LL
2. dont get an MSI, get an ABIT!
3. dont get a NEOPOWER, get an OCZ because neopower cant handle MSI
4. dont get a MAXTOR, get a seagate! (i was going to get a seagate, but i found a maxtor 250GB for $130 in FS/FT)
High post count doesn't neccesarily mean much, but here's my take on the situation:
1) You can do better than TT for the money, but it's not the end of the world.
2) MSI is fine.
3) NeoPower is fine.
4) This one I have to agree with. I read so many problems about Maxtors, not just failing, but also causing other issues, that I find them impossible to recommend any more. I suggest SeaGate and Western Digital, preferably SeaGate.
Anyway, I wouldn't sweat it too much. You should be fine with that stuff - the only thing that worries me slightly is the Maxtor.
I agree high post counts dont mean much. Since many people have mixed feelings about things and if someone get burned by a brand then it goes on the bad list for them. I had this when I decided to go with the MSI board. People either love them or hate them. The only reason I picked the OCZ Modstream is because it is a few dollars cheaper and has sleeved cables. I am sure for your system the Neopower will do fine.
If u care about the noise then just replace the front fan. I guess the noise doesnt bother me at all, but quieter would be ok. what i'm looking at down the road to quiet my system down would be:
-Koolance Exos for 3400+
-Front 120mm Panaflo
-Some sort of fan controller
It's not too much noise by any means IMO, and it's a great case.
Thermaltake = no thanks.
I agree, however, this case is an exception. It is very nice and the dual 120mm fans make it very quiet as well.
I still think Tt is poor quality and all that crap, but this case i can actually recommend.
-Kevin
-Kevin
Agreed. I would not recommend a TT fan or PSU to anyone but I WOULD recommend the Tsunami. If people learned to be objective.....
-Kevin
Easier to steer clear of them altogether than to bother memorizing one or two good products. I point people towrds CoolerMaster, where they can pick up a wavemaster, which is basically the same case. I do wish CM would get over the 80mm fans already, and move up to 120s.
the case isnt what makes the noise, its the fans in side the case. your using stock fans, thats the problem. get some good fans from silenx or zalman and that will solve your problem
Almost bought the TT Tsunami before opting for Silverstones TJ06. After Anand's review I could NOT pass it up.
Super cpu cooling at fairly low noise levels.
Hope you be liking the Thermaltake.
I have the Tsunami with a solid side panel. Not the clear side with the extra side fan.
And its pretty damn quite considering all the componets and fans I have stuffed in it. I think the window model must be considerably louder.
If low noise is a serious concern for you application, I would stay away from cases with a side fan.
Add some sound insulating materials to your case (or buy a case thats already well insulated). And replace noisy fans with better noiseless models where possible. And you can also use NV silencers on you GPU(s)
I,m continually amuzed by peoples desire for "MORE POWER" but demand for low noise level. "I have a FX?? overclocked to ????, 2 x 6800ultras, 7 hard drives and the Megatomic CPU cooler, but damn this thang is loud!"
If you build a hot rod its going to make some noise!
hmmm, i could always resell it or trade it for a seagate . . .
But IMO u will not be sorry with the Tsunami. It's nice too look at, and as soon as i get a black 17" LCD monitor there's gunna be a pretty nice color scheme (silver and black on everything, speakers, keyboard, u name it).
My only problem is that the front 120mm fan doesnt move too much air (possibly because it's a bad fan or the air is blocked by the front plastic grill). Anyways, i'm very happy with it!
My wife's new case is the Tsunami. Neither the front nor back fan breaks 1000 rpm. The only way I know the computer is on is by the glowing LEDs on the front and the glowing 120mm fan in the back. All fans in the case are stock. Power supply is the NeoPower 480. From all I have read DO NOT get the stock ThermalTake PSU.
My friend bought the Tsunami as well. He doesn't like the flex in the case so he's getting the new ThermalTake Armor (ATX/BTX) case. His (Tsunami) case is quiet as well. Both cases have the X-side window. We both looked at the WaveMaster and we don't like the 80mm fans. If I had to choose between the Tsunami or WaveMaster I would stay with the Tsunami. The best of both worlds, IMO, is the SilverStone TJ-05, but more than I want to spend.
All of this may be moot if you are overclocking or have more cooling needs than we do. As Insomniak said, Tt isn't the best, but you could do far worse, IMO. It's got the looks I want for a better price than the SS and WM without the drawbacks of the WM. First choice for me would be the SilverStone but I don't want to spend the cash for it. 🙂
All my 0.02USD, YMMV, etc.
I was going to get the tsunami but decided on the *soprano*. This case is very nice I have no complaints *Edit* I originally put sonata, got it confused
Pretty good????? are you serious?
Just buy either Antec, Enermax or Zalman fans for that extremely beautiful case you just bought.
Find a fan controller you like too to regulate the speed of those new fans you buy.
Okay, this has been my wife's case for the past month or so. I am planning on getting one for myself as it's a good case for the money.
My question: Has anyone removed the top pod and replaced it with a fan? Even though it has two 120mm fans and the side mounted 90mm, I'd really like to put a top mounted fan.
You dont need any more fans. In fact that side panel fan is a waste. I would take that side panel fan out and then stick that on top if you really want to. But the 2x 120mm fans (1 front, 1 rear) should be PLENTY. Anymore and you create a sort of vaccuum that starves the CPU fan for air and other comoponents for air.
-Kevin
I can live with the noise (once I get a fan controller), but what really pisses me off about this case is the damn retention clips for holding the cards in. Damnit, every time I want to plug something into the add-on USB port, I gotta take the side off and hold the damn thing or it'll pop the retainer and land on my video card. Add to that, that the design of the retainer makes it nearly impossible to use a screw and you're....well....screwed!
I like the case in most other respects but that problem is a major flaw. I'm going to drill out the four rivets on that cheap plastic excuse for a retention device this weekend and chuck the damn thing out with the trash! Maybe then I'll finally be able to get some screws in there to hold things the way they were meant to be...
EDIT: Anybody know if the Vantec Nexus NXP-305 fan/light controller will fit a Tsunami?
I've never had a problem with the retention clips. However, now that I shoved two more hard drives into it last night, I will say that the hard drive bay is rather flimsy. I'm glad that I don't add and remove hard drives very often.
Now that I have two more hard drives in the machine, the fans are getting a little loud. It's not enough to bother me, but now I know why people are complaining about it. 😀
I've had a Tsunami for about 2 weeks, I love it, but its a little loud. (I can't hear it in the next room let alone down the hall) but I was wondering if Silverstone products are worth the premium. The Temjin-05 looks real nice, and I can afford it, but I don't think its worth the extra money. What do you guys think?
psh, FANBOY
Man I feel bad for you, don't let others pressurize you into changing your components.
I mean, heed their advice - yeah, they might have first hand information, but don't let some people bully you 🙂 (Especailly fanboys)
Here's my take:
On the ThermalTake note, some poeple love it, some people hate it.
Overall, it's not bad case (Tsunami) - looks are subjective. What tends to drive people away from TT is the noise, I think that's one main area they should focus on. I think there's a general concensus that it's probably not the best bang for the buck when it comes to quality - but hey, if you like it then go for it.
But then again I shouldn't be talking about "Quality" - I have an NZXT Guardian.
In my opinion, a case should have 3 things:
1) Cooling - Depending on what components you have
2) Quietness - This is subjective, depends on person to person. Some guys have their computers locked up into closets (I'm dead serious).
3) Looks - Get a case you like 🙂.
About the MSI vs. Abit. I can't really comment on them as I have an Asus. But there's something you should definately know - "brand loyalty" isn't everything.
Since I've been an ASUS fan (reliability and all that) I was about th recommend the A8N to my friend... until I saw the numerous posts regarding the problems. That's fine - most of these have probably been resolved. I don't mean to troll or anything - but "brand loyalty" can't always be applied to boards. Now, of course everything has exceptions. Some boards tend to be more overclocable than others...etc.
Get what board fits your situation (budget, overclocability, features). It's not the brand, it's the board. "Good" brands can come out with bad boards (the asus for example), but "bad" brands can come out with good boards as well (soltek made a good nf3 entry).
Neopower is fine, like Insomniak said.
I agree. I've had lots of problems with maxtor in the past. Then again, it could have just been a bad egg... it happens sometimes.
I prefer seagate, as most of them have FDB motors (long term quietness) and long warantees (5 year warantees)
Now, that doesn't stop me from buying maxtor again... They could come back with a kickass drive.
Get whtaever one suits your budget.
Bottom line: Brand names don't matter - the product does.
Bottom Line 2: High post count doesn't matter at all. It could simply be some trollers or people who post a lot on ATOT (AnandTech Off Topic) 😛.
Back to the original post:
I've actually seen this case at a LAN Party. It looks pretty sharp (but then again, looks are subjective). The noise.... well.... it was definately the loudest thing at our lan party so we just increased our speaker volume 😛.
I wouldn't worry too much about the noise though, I've seen comptuers with vantecs and sunons and deltas ... and oh my god, after hearing those, the tsunami is NOTHING 😛.
If you haven't heard a delta (200 CFM - TWO.. HUNDRED.. CFM!) - think about SOMEONE SCREAMING RIGHT IN YOUR EARS.
Yeah!
That should make you feel better about the Tsunami 😛. If you're really concerned about the noise, just get a couple panaflow L1A's (L1A means Low, M1A means Mediu, and H1A means loud).
Uh - one last thing though. It seems as though people who say that the Tsunami is loud, run the fans at max speed. Err... hook it up to the 'FAN_ONLY' thing of your power supply (I think that's what it's called). I don't think you'll be running these fans on full load except on games (where you can simply turn up the speakers 😉).
-The Pentium Guy
Edit: Holy crap! Look at the quote on quote on quote on qoute on quote!
