Bedbugs! Argh
Bed_bug&
Makes your skin crawl
I just went through an infestation last summer. They can move between apartment units. They like to hide in the AC outlets and also can crawl through the AC heating vents.
It took three visits from the exterminator and allot time and work on my part to get rid of them.
1. Treat your bed. You can buy mattress covers that will seal in the bedbugs for $50 at Walmart Target. Get two since most bedbugs love to hide in the box springs. Wash your headboard and endboard with Murphy’s Oil soap. Wash all bedding and make sure you dry it on hot setting four 2 hours. Pull the bed away from the wall. Place metal bottle lids on the bottom of the bed frame posts. This will keep the bugs from crawling up from the floor.
2. Clean all wood furniture with Murphy’s oil soap and be very thorough. Bedbugs love to hide where it’s dark. They will attach themselves to a bottom of dresser drawers.
3. Wash down the baseboards and have the carpet steamed cleaned. Also take the time to apply extra steam near the baseboards. They love to hide under the carpet near the track strip. I used a steam iron and wet towel along the baseboards to kill them off.
4. Now you need to inspect your living room furniture. If you’re infected there. You will have to decide how much your time is worth saving your furniture. I was lucky. Since I live in Las Vegas. I was able to seal my sectional in plastic sheeting and place it in the hot sun when it was 110 and let it set for two days.
I found a couple of good forum threads after a Google search that was really helpful. One was at Something Awful.
That was a very helpful post 🙂 I pray to god I do not get an infestation.
In addition to what Raincity has stated; you can purchase a powder that they will track back to thenests and kill them. the powder needs to be spread whereever they will be traveling.
My daughter inherited an infestation after visiting her inlaws. She ended up tossing all her bedroom stuff; then asked me to replace it for her.
She located a powder online that was eco-friendly and used it with no problems afterwards. It was about $50 for a 2-3 room application - guarenteed results.
Oil and heat will kill them where they are accessible to you.
Do you remember the name of this powder offhand?
I remember getting a series of bites on my arm at night in college. I thought it was a bunch of mosquitos so I'd cover myself in mosquito repellent during the night, which was no help. Later, I did some researching and found out that the bites were bedbug bites so I searched all over my bed to find them. I finally found one in the back of a drawer. Removed it and no more bites. I was lucky for it to be only one. I was pretty creeped out by the number of bites on my arm.
I think they crawl up walls, not through them :^D
I imagine it's just a new infestation. They have to eat. They weren't just hanging out inside the walls starving to death, and hoping someone would set them free :^D
Well, they can survive nearly 18 months without feeding.
As for the OP, don't throw your mattress out. As someone said, buy hypoallergenic mattress encasings and put one around your mattress and the other around your box spring. Thoroughly clean your bed frame. I've heard people have had success with placing the legs of their bed frame in tupperware filled with mineral oil. It will prevent them from crawling up the bed legs and into your bed.
I would definitely call an exterminator, steam clean your carpets, and be very careful about getting into and out of bed.
These guys are pesky and can be extremely hard to get rid of.
The only powder I learned that works is boric acid and diatomaceous earth. I passed on the boric acid since I have a cat and did not want the powder getting on his paws. The only place I could find diatomaceous earth locally was at a local nursery and they only sold it in 10 pound bags. Extreme heat and cold is only sure fire way to kill them. At the resort where I work. They use a portable furnace to treat infected rooms. They toss the mattress and box springs. Then use the portable furnace to heat the room to 140 degrees for four hours and treat the residing rooms the same way.
Ok... at least now I'm on the right track. Next stop I'll be heading to walmart for dry ice, and a catfood dish. I looked around online and found several different powders, so I'll try and order some and see how it performs.
It sounds like a gigantic pain in the rear to create a circle of powder around my bed but it will be better than constantly getting bit up every night.
Yeah, I know of a place that treated them by using a large pan of water with a heating element. They would put it in the middle of the room with a small CO2 tank emitting gas and turn it on. Leave it for a week and you'd have hundreds of dead bugs floating in near-boiling water.
Wash your sheets and enclose your mattress before you try and seal yourself off. Also remember that they can climb walls.
Sister-in-law moved into an apt infested with these things.
She had to throw away her new bed and most of her belongings. These things were everywhere.
None of the home remedies or sprays even made a dent.
If you turned on the lights at night in a room someone was sleeping you would see them scurry for a hiding spot. Ugh.
Wow... sounds pretty weird, I don't know if the landlord would allow that though.
Actually this sounds promising. I'm looking to tackle this from a DIY perspective; any ideas on where I could get a cheap heating element? I'm going to pick up the dry ice on my way home today along with the 1/3 gallon container to let the CO2 leak out from.
I was thinking some more about it, and realized that when my wife and I first moved into the apt we had a few bites here and there. It wasn't the crazy amount she has now (literally 30 - 40 bite marks starting from her ankle all the way to her chest), but we did have a few here and there.
I'm thinking now they must have been there all along and just started breeding. I need to get this under control quickly before it becomes a full fledged infestation.
Good luck even finding one of those portable furnaces. There are professional companies that use this technique. You would have to call around to see if its available in your area. The only way i was able to physically and mentally cope with the infestation because I was unemployed when I battled the infestation. I spent two weeks at war and would not stop until those f@ckers where gone. My neighbor’s three units down are still infested. They just won’t put the time and effort into getting rid of them.
Me and my family were showing up with bites from what we thought was bedbugs as well.
We took one of the bugs in to the college and they told us it was a carpet beetle.
The look like bed bugs, but don't bite.
They have waxy coating that when you lay or have any contact with it you get itchy and get what looks like good ole bed bug bites.
We simply bought this carpet powder that eliminates it and kills fleas, ticks, beetles, bedbugs, etc.
Worked well and never had the issue again.
Yeah, you could build one easily. Buy a cheap electric kettle and modify it. I doubt you need much C02, either. Once your bed is isolated, you should be killing these guys en masse every night. One thing to consider: even if you stop finding dead ones in the water, there may still be younger ones around the apartment.
As for the infestation, remember that these guys are really durable. They could be in other apartments and, even if you rid your apt of the problem, it could quickly return. I don't necessarily believe that the furnaces or heaters work very well, because I don't see why the bugs wouldn't simply crawl through the wall into a cooler place until the heat had dissipated.
My advice would be to check with your neighbors and see if they're having problems. If problem isn't simply confined to your apartment (as in true infestation), any measures you take likely will not be permanent.
One last tip: I had to deal with these fuckers at the end of a lease on my old apartment. The laws in Canada are different than here in the US, so if I couldn't definitively prove that the bugs were there before I came (they must have been), then the landlord is under no obligation to do anything. Left to my own devices, I isolated my bed, washed all my clothes and stuck them in huge zip lock bags. I was extremely careful to never let anything I wore around the apartment come into my bed.
Anyway, to make sure that the isolation was complete, I started marking the bites I had with a permanent marker before bed. That way, when I woke up in the morning, I could quickly tell if any of them had penentrated my fortress. It's a good way to stay sane, because those bites itch for a long time and it can be tough to remember which are new and which are old. My marks were just a dot on top of every bite. Most weren't visible and the marker washed away easily enough in the morning.
In addition to what Raincity has stated; you can purchase a powder that they will track back to the nests and kill them. the powder needs to be spread wherever they will be traveling.
She located a powder online that was eco-friendly and used it with no problems afterwords. It was about $50 for a 2-3 room application - guaranteed results.
www.begbugpowder.com
I understand the bugs are attracted to CO2 but since a gas, what are they attracted to? Do they home in on the nozzle, or what? If you emit CO2 gas from a tank, why would the bugs decide to crawl into the pan of water?
