Battery - OK to use slightly bigger size?
WildHorse
5,006
Say the car originally came with a certain battery "Group number."
Stores around me all sold out, no new stock expected for a long time.
IS it OK to put in a slightly different battery with a different "Group number" as long as it physically fits?
c3p0
2,494
Car batteries are car batteries basically. Amperages may be different and they may be different sizes. But as long as it physically fits it will probably work just fine. Make sure you get a battery that fits the type of connectors you have on your battery cables though. When in doubt, take it to a mechanic.
c3p0
:beer:
Vetterin
973
Any battery will work as long as it has the minimum Cold Cranking Amps needed for your car and will physically fit in your battery tray. If it's too big for the tray you can always mount it in the trunk.
steppinthrax
3,990
:thumbsup:
alkemyst
83,769
19
:thumbsup:
QFT.
I have upsized my batteries in the past with ones with more amps that would fit in the tray. Usually all you need is a slight modification to the hold down if anything.
biggestmuff
8,201
:thumbsup:
My car has the battery mounted in the trunk; stock from the factory like that.
alkemyst
83,769
19
:thumbsup:
You could be limited on size then depending how the factory setup is.
Bosconian
57
:thumbsup:
QFT.
QFT ^ 2.
The primary things to look at are physical size, terminal location and that it has the MINIMUM CCA's.
Like a computer PSU, there's nothing wrong with having a 1000W when all you need is 300W as long as it fits in your case. ;)
steppinthrax
3,990
:thumbsup:
QFT.
QFT ^ 2.
The only 2 disadvantages I can see of having a large battery is:
1. If the battery ever goes completey dead the alternator will be taxed more to charge it but.
2. Car manufactures do a lot of research in balancing a car so that the battery's weight is taken into account.
But all in all I think they are negligable disadvantages. I'd be more concerned with the 1st one.
steppinthrax
3,990
:thumbsup:
A lot of people switch to trunk mounted batteries. Heat is #1 killer of batteries and if you put it in the trunk you cut down on a lot of that heat. The #1 best place to put it is somewhere in the cabin (like under the rear passenger seats). My sister's Pontiac is like that. In that sense the battery is A/C cooled!!!!
franksta
1,967
Out of curiosity what freak-sized battery do you have that is sold out everywhere and nobody is getting one in stock soon?
Vette73
21,503
9
Watch him say miata ;)
Arkaign
20,736
1,379
I used differently sized batteries in all of my Hondas. The stock smaller battery was actually more expensive than the generic Wal-Mart battery that I replaced them with. They always lasted at least 4 years as well, starting every time. No small feat in Texas, where the temperature and humidity are about as spastic as Lindsay Lohan on coke, diet pills, and vodka.
andylawcc
18,183
also, make sure you have the terminals on the correct location/side. (positive on upper left, negative on upper right)
for my previous car, the connecting cables have EXACT length, so should the positive be on the lower left or upper right, i will be screwed.
thomsbrain
18,148
If it will fit, it's totally fine. I put in a larger size on one of my cars because that's what they had. It lasted the next 100,000 miles I owned the car, despite some 105+ degree heat waves and sub-freezing starts.
WildHorse
5,006
First, it's not my car.
The size needed was called Group 35.
