Batteries for UPSs
G19
78
<< SOMEBODY HELP ME OUT.
I've got an APC "Network Powercell BD". I can't find any reference to this particular model anywhere (except APC). I've been looking for batteries for it for quite sometime now. I haven't been able to locate any with the same deminsions as the original. I've noticed that most websites, like Parts Express for example, neglect to mention the demisions of their batteries which seems kinda lame to me.
Does anybody know what this beast is and where I can find the correct batteries ?
Thanks
Strangely enough I just replaced a set of batteries on that exact same model UPS around 2 weeks ago. The best deal I found was $14.39 per battery at www.GotBatteries.com
arcas
2,155
*sigh*
>> That's absolutely preposterous. The voltage vs. capacity curve always falls
>> more gradually when draining at a lower current - that is, the usable battery
>> capacity will fall at higher discharge rates. Undoubtedly, a car battery would
>> last a hellava lot longer than the builtin unit in this situation, so....if you
>> do not know what you're talking about . .
No...sit down. Re-read what I wrote. Pay particular attention to the definition of the word "lifetime." Note that I did not say "capacity" or "reserve time." Though after a few deep discharges using a car battery, you might well be able to substitute either of these terms into my statement.
Next, examine the physical differences between a typical high-current car battery and a deep-cycle battery. I refer you to the "Deep Cycle Battery FAQ." There are a number of copies floating around the net but you can find it here.. In particular, I refer you to section 4.2:
<< Car batteries are especially designed for high initial cranking amps (usually 200 to 400 amps for five to 15 seconds) to start a car and not for deep cycle discharges. Deep cycle (and marine) batteries are designed for prolonged discharges at lower current. [The plates in car battery are more porous and thinner than in deep cycle batteries and use sponges or expanded metal grid instead of solid lead.] A deep cycle battery will typically outlast two to ten car batteries when used in deep cycle applications. Starting an engine will typically consume less that 5% of a car battery's capacity. Whereas, deep cycle (or marine) batteries are used for applications that will consume between 20 and 80% of the battery's capacity.
-- arcas
hevnsnt
10,868
I love you guys...
I just, I mean Just got a APC from a business that was throwing the dead ones away... I checked on APC's site and the batteries and I was not going to be able to replace them for much less than $100
DanFungus
5,857
Thanks for the heads up worm
I have my 350VA from CC Black Friday for $9.99, and I have an athlon 1.4 and a 19" monitor :) hooked up onto it, and power off, BEEP BEEP BEEP. RAR. Wanna get a 500VA or more, but I will probably only be able to spend up to $20 for it.....as in, not likely.
RayH
963
I'm currently trying out BatteryMinder which is supposed to be able to revive some dead batteries. Not sure if it actually works or not but if it does it could save alot in the long run.
hevnsnt
10,868
Ok, it looks like I need to replace 2 RBC5's
which this is written on them: 100A 48V Buss F1B-100
Anyone know where I can pick up a couple of these cheap?
youseelabruin
477
I got a: Back-UPS Pro 280 that uses a RBC2
So which would I order from http://www.gotbatteries.com/ ?
w/0.187" Fast-on Terminal
or
w/0.250" Fast-on Terminal
PS-1270F1 Availability:
24 Hours
Power-sonic 12v 7.0 Ah Sealed Lead Acid Battery w/0.187" Fast-on Terminal Your Price: $
17.85
LC-R127R2P Availability:
24 Hours
Panasonic 12 volt 7.2 Amp Hour Sealed Lead Acid Battery - 0.187" FASTON Terminal Your Price: $
21.75
LC-R127R2P1 Availability:
24 Hours
Panasonic 12 volt 7.2 Amp Hour Sealed Lead Acid Battery - 0.250" FASTON Terminal Your Price: $
21.75
PS-1272F2 Availability:
24 Hours
Power-sonic 12v 7.2 Ah Sealed Lead Acid Battery w/0.250" Fast-on Terminal Your Price: $
17.85
Bob/NYC
Mine has this one-dead: LC-R127R2P1 12v/7.2AH/20HR
