There are a couple reasons why you generally do not want to use a car battery in a household UPS. First, car batteries are designed to
deliver very brief bursts of very high current. This is quite different from the slow drain load placed on a UPS battery in the event of a
power failure. A car battery is likely to have a short lifetime in this role. A better solution would be a "deep-cycle" battery like you'd find
in boat stores for powering trolling motors over long periods of time.
But there's another reason why you don't want to use a car battery in your house: it's not sealed. When the power fails, the chemical
reaction inside the battery will release hydrogen as a by-product. This means you need adequate ventillation. Not to mention the possibility
of a battery leaking sulfuric acid all over the carpet
If you're looking for a replacement, take a look at sealed lead-acid or gel-cell batteries used in jetskis and snowmobiles. I have read
reports of people replacing their APC 1400s batteries with "sea-doo" batteries (they apparently fit!) with double the capacity. When my
1400's batteries die I think I'm going to try this.
