Originally posted by: Marlin1975
Me and my wife bought a forclosure house. We gutted the master bedroom and bath and tore a lot of the other rooms up. Here is what I found out...
Don;t waste your time on greenboard. Even greenboard makers changed their stats on greenboard after it has shown to be alomst no better then regular white board in most uses.
What I did was use
GP DensArmor drywall (Lowes) for the bathroom and hardibacker for the top of the tub surround. I will use a
Schluter shower kit over the GP drywall for the walk in shower.
Plan to take longer then you think it will take to do the job. Don;t rush as a water leak after the wall is up will be a real pain. If your are not 100% sure about a fitting or connection then take it apart and start over. I did that several times with my tub and I did not call the drywall guys until i was REALLY happy with all the wiring and plumbing.
Go ahead and use 12ga wire and wire any room for 20amps. You never know what people will use in a room so don;t try and pinch pennies by using 14ga wire and 15amp outlets. Here is a site to where I got my
CGFI outlets. they have free shipping and are much cheaper then any other place i could find, even eBay. They also have bathfans and other items so i ordered a fair amount from them.
For the person that said they had a problem with a pipe fitting, in a pinch you can use whats called Sharkbite. It connects copper pipes without solder/flames/etc... I have used 3 in our bathroom remodel as there was to much water in the pipe for me to get a good solder on them. They cost around $5 each so not really worth doing a full bath in them but for trouble areas they can save a lot of time and headaches.
Any other questions i will try and help with what i know and have learned from my work so far.
