Basic question on how to get HD Component Analog out of a PC
JonoZee
Some assistance is required:
A basic question towards building an HTPC. I want to continue to use my Phillips CRT TV which only takes Component Analog in, not HDMI.
Can I choose any Graphics card that has a D-Sub connector and then just use a simple "VGA" to Component RCA adapter cable?
What about CPU's with integrated graphics? If the motherboard has a D-SUB out, does that mean I am good to go?
Anything else I should be looking out for?
Thanks in advance.
Fox5
5,957
7
You could get an older video card that actually has component output and use that.
However, if your CRT TV doesn't have HDMI, it likely doesn't do HD over component. I had several Phillips CRT TVs, if they just had component they only did standard definition (480i resolution), if they did HD, they also had HDMI.
I don't think a vga to component adapter will work.
Something like this would work.
http://www.monoprice.com/Product?se...&cagpspn=pla&gclid=CJqP8dr33boCFU7xOgod1HMA2g
VirtualLarry
56,587
10,225
my 9600GSO PCI-E cards had a TV-out port, and came with a component output dongle for it.
Iron Woode
31,368
12,858
I had that issue with my old rear projection tv and my old Toshiba crt tv.
some old ATI cards came with S video out and a dongle that could do analog component video.
SPBHM
5,076
440
g[/url]
some TVs had at least 480P/1080i support and no HDMI input
my last card with component output was the 9600GT (2008), I think other cards from that era probably have the same.
it's easy to identify, normally it have what looks like an S-Video connector.
KingFatty
3,034
Agreed, you need to dangle the dongle. I too have an older laptop like this, where it's a funny looking port (shaped like a PS/2 port but with a bunch more pins) that you insert the dongle and get the component video outputs.
