Basic Projector - Small Business
mhs
11
Looking for recommendations for a basic, sturdy projector for a small business. Bi-monthly use, must be easy for non-techies to use. Thanks
sdifox
101,207
18,220
any mobility requirement? as in do you need to take it out of your building and go to client sites?
mhs
11
Nope, we'll have it in the office at all times. It should be fairly portable - we have visiting speakers who like to use their own laptops to connect to the projector.
sdifox
101,207
18,220
if it is in the office and presumably in the same room, why would you make it portable? Just go fixed installation.
The reason is the stuff marked as ultra-portable are compact first, functional second.
Also, how big a room and how big a image size do you want?
Lighting condition when projecting, are you able to turn off some of the lights if not all?
mhs
11
The room in question is also leased for film and TV shoots - unless the installation is stellar, mgmt does not want any permanent tech installations in the room. It would be best if we could bring out the projector only when needed.
sdifox
101,207
18,220
ok. so table top is fine? Budget?
mhs
11
Room can seat 60 people comfortably - lights can be turned off and dimmed. Room has large windows which do not pose a problem - most use of the projector will be during evening hours.
sdifox
101,207
18,220
I imagine you want a bigish image for 60 people. Any target image size and are you looking for 4:3 or 16x9?
budget?
sdifox
101,207
18,220
I am really not sure on the image size - recommendation?
It's really a function of how the room is setup. Do you present to 60 all the time? How are the 60 setup, rows of seats or around a conference table?
mhs
11
We set-up usually from 4-30 people at a time. We have a large conference table in the center of the room and then chairs around the outer edges of the space.
sdifox
101,207
18,220
that probably means you need a bigger image. How big is the screen and is 16x9 image desired? Most bargain projectors are still 4x3. especially the conference room type.
sdifox
101,207
18,220
16x9 image would be great but may be an overkill?
You don't got the cash for it. Thing is 16x9 projectors are aimed at home theatre and as such do not have as high an output level as business projectors. They also cost a lot more.
Take a look here.
