13Gigatons
- Apr 19, 2005
- 7,461
- 500
- 126
You called him at 2am for an "emergency call" that's an hour+ drive... probably woke his wife, kid, etc.... then call him and tell him LOL Nevermind? You're lucky he didn't show up and face stab you.
Water level alarm is a good idea.
Battery backup for sump is a good idea, but in this case his pump had power, but pump itself was bad.
Water entering foundation must be fixed. That will involve excavating around it, weeping tiles and gravel and proper installation of waterproofiing membrane on the foundation walls.
You should also buy and keep a spare sump pump or even one that can be placed outside the home to help in an emergency.
Sump Pumps should be replaced every 5 years.
ORLY?
ours has been running for nearly 15 and is used near daily as the washing machine and utility sink in the basement empty into it
ORLY?
A pump may last that long. It has rubber seals in it and they like to be kept moist and soft. If it doesn't get used, they dry out, then can't make the suction the pump requires. The pump Anubis mentioned may not be for sump, but may be what is known as an ejection pump. Commonly used where bath / toilets are below the level of the drain pipe leading to the sewer / septic.
That's just scary.
Not the pump lasting for 15 years but that it serves as a pump for the washing machine and utility sink. How far out in the boonies do you have to be for this setup not to be against code?
that's exactly why we have it, we had the washer going UP to the line but that failed more then once and after that it went to the pump,The pump Anubis mentioned may not be for sump, but may be what is known as an ejection pump. Commonly used where bath / toilets are below the level of the drain pipe leading to the sewer / septic.
i live in town actually, the sump pumps into the sewer line.
interesting, it is in the lowest point and tied to the correct walls, floor drains drain into it from most of the basement, its in its own little room with its own door, open pit style pump can get fully submerged. came with the house. plumber is the one who suggested sending the washer there.
It should. Ideally the sump pump should be located in the lowest point of the basement and tied into the interior weeping tiles if they exist. The clean out cover should be metal and secure against children.
What makes dumping the laundry water into the sump against code is overloading the duty cycle, damage to the pump from detergent and fibers, the possibility of siphoning and, critters due to standing water.
Ejection pumps are made differently and have a different type of closed tank system. Using a sump for this type of double duty is against code everywhere I've ever heard of, at least in the lower 48.
Well for one thing, it sounded like the OP's dad just wanted to update the repairman on what had transpired in the meantime; the repairman jumped to the conclusion that this was a "never mind, please turn around, and we won't pay you" response, and immediately reacted emotionally. A kinder, non-asshole response would have been, "I see. Do you still want me to stop in? I do still need to charge you the $200 minimum for starting to drive out."Or .. how about.... You attempt to fix it FIRST... and then call the repairman... you know... like most normal people do?
Most MEN don't panic like a pansy chick and call the first repairman in the book at the first sign of a simple issue.
I had no idea what a sump pump was before this thread... we have sumps around town, a handful of them the size of half football fields, but nothing "in our backyard". What do yours drain into... is it a sewer line or into a big sump like that? I don't even know of an existing system at our new place that would help us in a situation like yours.
ORLY?
