Originally posted by: ImmortalBlade
 Analagous to AMD's Slot A to Socket A transition
			Pent3/New cellies-Socket 370
 Last generation product. Do we care about the K6 too?
No the Slot A-->Socket A switch would be analogous to the slot 1-->socket 370 switch.  The pentium 3 was the current intel chip when the Athlon came out at 500Mhz.  Also, there was a logical reason for the slot--> socket switches due to the integration of L2 cache in the cpu die.  The socket switches can't really say that.(I could understand P3-->P4 requiring a diff socket due to the different architcture, but switching to socket 478 only a year later is either poor planning or just an attempt to shaft early adopters.)  Also keep in mind that Intel delayed the entry of DDR for the P4 for a long time, which stuck you with RDRAM(Very expensive at the time, and moreover, if you were upgrading you would actually prob need newer RDRAM to notice much performance improvement due to the bandwith hungry nature of the P4.)
			So lets think, upgrade from p3 to p4. Whoops need new mobo at least, if not also new ram because Intel switched from SD to RD and now you can use RD or DDR wow... so similar to AMD where i can stick my XP into my old T-bird mobo(again with new bios) and use my old SDRAM if i wanted to.
			So lets think, upgrade from K6 to K7. Whoops need new mobo at least, if not also new ram because AMD switched from SD to DDR... so similar to Intel where i can stick my P4 into my old i845 mobo(again with new bios) and use my old SDRAM if i wanted to. Older Socket 478 motherboards work just as well with recent P4s as do older Socket 423 motherboards do with recent Athlons. If you want to go to unofficial means, then even Socket 423 motherboards can use recent Northwoods with an adapter, which is more than one can say for Slot A motherboard owners.
Actually going from a k6 to a current Athlon would be much easier as there are boards that still take sdram for the athlon.  There are even boards that take both sd and ddr ram, so you could hold on to your old RAM and upgrade to ddr later.  and of course, lets not forget that the Athlon's performance isn't totally crippled by using sdram like it would have been for the P4.  Keep in mind that a k6 is now a very old chip(it's really more of a pentium 2 Analogue.), so you really ough to be considering a PII-->P4 upgrade with your argument.  The problem with that is most likely that your SDRAM is a wee bit too slow for any modern platform.(Maybe even PC66 if you are talking about an original Celeron)
