joshhedge
- Nov 19, 2011
- 601
- 0
- 0
I wasn't using the specific heat of water.
I was using the heat of vaporization of water as I was planning on having only the vaporization of the water as the primary heat dissipation method out of the system.
I see, but where are you planning on the water vapour going? Will you be condensing it back into the system? Either way there will have to be heat transfer to the surroundings. As a chemical engineering student, I don't believe vaporisation to be the most efficient form of heat transfer for this though. You're best off having the radiator next to a window, or an area with good air circulation and keeping the system in the liquid state.
