Worked for me. I had the same problem early this month. I ended up getting the tire off by kicking the hell out of it.Originally posted by: bootymac
Undo all the bolts and kick the wheel at 6 o'clock and 12 o'clock, then at 3 and 9 o'clock until it comes off
Originally posted by: moshquerade
ohhhhhhh fuuuuuuuuudge
(but i didn't say fudge)
Originally posted by: rhino56
friend of mine had a rim rusted to the back hub on his suburban, he has to do the loosen the lug nuts and drive it until it oped of. he had to spin donuts like 5 times before it broke loose lol
Real good for the hub when it slams into the ground also...😛
Try a small propane torch around the lug pattern then hit it with a sledge ..
Originally posted by: waggy
as title says i got a flat and can't get the darn wheel off. fricken ticks me off. we think its frozen on =(
Originally posted by: deadlyapp
put some PB blaster there if you actually have the nuts off.
yeah got the nuts off. but wtf is pb blaster?
Originally posted by: mercanucaribe
Pour hot water in there. Prying will probably damage the hardware.
tried that. trouble is i have pretty bad arthritis in my hands. so i can't be outside to long or work to long on it.
not sure if its frozen or rusted on. darn cars.
Originally posted by: Pepsi90919
why would you take the tire off the car? wouldn't you take the wheel off with the tire still attached? 😕
Originally posted by: gsethi
Make sure you are using a jack 😛
Also, do you have wheel locks ? If yes, did you remember to take it off ?
