Bad gas mileage? Whats the problem?
compuwiz1
Admin Emeritus Elite Member
930
If your car is not specifically calibrated to run premium gas, you could actually get worse mileage by using it. It throws the computer off.
Rubycon
Madame President
Aug 10, 2005
17,768
485
PEBGPADS
Problem Exists Between Gas Pedal And Driver's Seat. :laugh:
0roo0roo
64,795
84
222hp ..heavy big car. u pay!
camry hybrid gets 40mpg combined real world according to road and track test. not to shabby performance either.
0roo0roo
64,795
84
Originally posted by: Aquila76
Originally posted by: nakedfrog
Originally posted by: thatsright
Originally posted by: Strk
How fast on the highway? And if you don't need premium, don't use it.
Around 70mph.
I prob use plus gas after a while. Just givng it some premium to get it going.
What exactly does that mean, "to get it going?"
If the manual doesn't specify to use premium gas, it does you no good to use premium gas.
Wasn't there a study that showed this actually makes the car perform worse (putting prem. in a reg. car)? I think it had to do with the octane and residues left in the engine. Switch it back to whatever the last owner was using. The engine, ECM, and everything else have adjusted to that and you'll prob pick right up to where you should be.
Also, figure your actual MPG (miles / gallons to fill) and not going off gauges, as xrax suggested. My gas gauge doesn't even budge until about 80 mi. are burned off, and at that point it's down roughly a quarter tank!
yea i've heard the guages arent linear. they drop slow at first, its psychologically better or something:p
and yes no premium unless u need it. otherwise its money in the garbage. car and driver or something have a test of vehicles using different gases awhile back.
nakedfrog
62,838
19,056
Well on the gas door it says "Regular Fuel Required. Premimum Recomended"
So you'll probably only get the advertised HP numbers using premium, but it will run just fine on regular.
Feb 10, 2000
30,029
67
This is about the mileage you can expect from this car. I have a 2001 Max SE (with 5-speed) and it always got about 23 MPG until the mileage abruptly got much worse about a year ago, for reasons my mechanic is unable to explain. Hope that doesn't happen to you!
nakedfrog
62,838
19,056
Tried Seafoam yet?
Feb 10, 2000
30,029
67
Tried Seafoam yet?
Nope, but I've tried other fuel conditioner/cleaners. I'm honestly stumped. The engine has always run perfectly and never thrown up a Service Engine Soon code. It has less than 58K miles, and has had all required maintenance.
The problem started when I moved to different tires (Bridgestone Turanza LS-Vs), but they are the right size and I can't see how that could be the issue. I now realize I had also put in an Amsoil air filter around the same time, but I later removed it to see if that was the cause - it made no difference. I am at a loss to understand this. The car now gets around 16 MPG.
promposive
912
Try regular, check your gas mileage. Probably will be better, and cheaper.
Also, may need sparkplugs/wires/rotor button/cap. Those will affect gas mileage if you aren't getting a nice stream of power to the plugs to ignite the fuel good enough.
Also, check your tire pressure, that will affect gas mileage and tire wear.
I'm sure a google search would turn up a few more tips on gas mileage.
SampSon
7,160
Are these mpg numbers based on actual calculations from filling your tank, driving and then filling it again?
Or just from the gas guage?
Your gas mileage is spot on.
Kadarin
44,296
16
Check your tire pressure. Low tire pressure will significantly decrease mileage. While you're at it, verify that your wheels are not significantly out of alignment, as that may also increase rolling resistance.
Vic
50,422
14,337
22 mpg sounds about right for that car. It's not a Geo Metro, yaknow.
BoomerD
66,291
14,710
Doesn't strike me as being particularly bad mileage for the car and the mileage. The O2 sensor COULD be bad, but only a diagnostic will be able to verify that, and they're too expensive to replace "just in case".
Excelsior
19,047
18
Originally posted by: ViviTheMage
I get 32 to the gallon on my Jetta :D
Back and forth from school (going about 75 almost the entire time) I average 30-32 in my Passat. :)
Eli
Super Moderator | Elite Member
8
Sounds about right.
What were you expecting? 40? :confused:
thatsright
3,004
Originally posted by: eits
don't you research cars before you think about buying one? jeez...
Yes.
Researched buying a car to death. Nearly 3 weeks of research/looking. I knew that the Maxima was no Honda Civic on mileage, etc.... but the mileage I'm getting now just feels odd.
As per a full tuneup, Its appealing. Im the opposite of a gearhead. This is my first ever car and so I don't know too much. I love the car even after this little 'surprise.'
If I get a tune up, I'll prob. take it to the Nissan dealership if the price is reasonable. I live in Boston and don't know of any shops that specialize in Nissan. Haven't called around. I'd love to get a referal from a Boston Nissan driver....?
A super 'not-car-knowing-stuff-guy' question. Would a tuneup price include replace sparkplugs, flud. I just have a feeling I'm gonna get gouged since I don't know jack about car parts/repairs.
Finding a mechanic who doesn't rip you off and knows what their doing is more valuable than your fist born child!!!
raildogg
12,892
572
Its a V6 Automatic
2000 Nissan Maxima, Automatic V6;
Fuel Type Regular Gasoline
MPG (city) 20
MPG (highway) 28
MPG (combined) 23
2000 Toyota Echo, 5 speed;
MPG (city) 34
MPG (highway) 41
MPG (combined) 37
LOL why buy a Echo when you can get something better for almost the same price?
jagec
24,442
In that case use premium.
It's true that it's a waste of money to put premium in a car that only needs regular, but putting regular in a performance-oriented car that's tuned for premium is also a waste....might as well have bought an econobox;)
My bike gets 50mpg, though, and I bet it could take you:p
