Not trying to hijack this thread, but I might be having the same issue.
Got the H220 installed, but getting high idle temps on the 3570k according to the bios. It is showing a cpu temp of 52-55c and that is at idle. I have removed and remounted 3-4 times now and reapplied the Noctua NT-H1 each time, but get the same temps. The ambient temp is about 25c.
I am also getting a cpu fan error message on the bios splash screen at startup. The cpu block/pump from the H220 is plugged into the Cpu Fan header on the Asus P8Z77-V Pro as called for in the instructions, but there is no reading in the bios for the cpu fan header, just an N/A. With an AIO water cooler like this H220, is there supposed to be an rpm reading for the pump displayed from the cpu fan header that it is plugged into?
Is there a chance that the pump on the H220 is not even working? Would having just the water block attached to the cpu, without the pump working. result in the temps I am getting, without actually frying the cpu?
