Automatic transmission car crash
Zenmervolt
Elite member
Oct 22, 2000
24,514
44
Originally posted by: eleisonwouldn't you rather have your car essentially dead AT the point of impact?
No, I'd rather not have the drive axle locked up resulting in a loss of control that makes the accident more likely. But that's just me. If you prefer to have no control over where you're sliding, that's fine, just don't share the road with me.
ZV
iamaelephant
3,816
Originally posted by: Zenmervolt
Yeah, the spark that is contained within the engine's head will magically leap out of an undamaged engine and ignite fuel. :roll:
People who don't understand how things work need to stop theorizing.
ZV
We are all theorizing here :) until I see credible data that shows how many manuals vs. automatics that have been on fire... I will still speculate that its mostly automatics. For all the safety stuff installed on cars that are suppose to prevent fires from happening, they still happen. As unlikely that you say it happens, there have already been a case in this thread alone of an automatic that as you say, "magically" caught on fire (the avalon)...
Okay dipsh!t, how about this. I had a 1990 Ford Falcon EA with manual transmission and 3.9l six cylinder motor. It randomly caught fire in my driveway, and we never did find out why. I can concluded from this story and your above example that manuals and auto have an equal chance of catching fire.
What's wrong with my reasoning? Well for starters, anecdotal evidence means squat. As I said in my previous post, autos will be slightly more likely to ignite because of the trans fluid, but NOT because of your stupid reason. It doesn't matter if the engine is running or not. Go read a friggen book about engines.
iamaelephant
3,816
Originally posted by: Evadman
Example: Manuals are more dangerous in an accident than an automatic. Know why? Lets say you are going down the street at a nice leasurly 40 MPH. Now, someone pulls out of their driveway and you hit them, cracking your flywheel.
Err... what?
You hit the other car so fast that your rear wheels came off the gound alowing your engine to spin while your foot smashes into the gas pedal, causing your engine to redline for a split second before the engine siezes from the impact.
WHAT?!
That causes yoru flywheel to fragment, taking both of your legs with it. the puny sheet metal of your floor will do nothing as the white hot pieces go right through your legs, on their way out of your roof. Then, since the flywheel is so hot, it starts a neigboring orphanage on fire. "Oh the humanity", you scream as you bleed to death and are forced to watch all the poor orpahans die horribly because you bought a manual instead of an automatic, since an automatic doesn't have a flywheel.
Okay seriously, WTF? You appear to know about as much about engines as the OP. Why would a flywheel break from a frontal impact? And why is the flywheel white hot? WTF? People on ATOT seriously need to start learning about cars or STFU about them.
eleison
1,319
Originally posted by: iamaelephant
Okay dipsh!t, .
Wow, I just don't get it. I ask a simple question asking for answers.. for statistics.. for data.. but instead I get called names.....
eleison
1,319
ZV
But the question is, would you rather have your car lock up as an automatic or a manual (after all most people when they get into accidents, they instinctively lock their wheels -- obviously, Zenmervolt is such a good driver, he never does that!!! but for regular folks they do :) In addition, after thinking about this some more.. If I was going 65mph (in 5th gear) and I slowed my wheels enough.. probably arround 10-15mph... the engine would still die.. it doesn't need to lock up. :)
iamaelephant
3,816
Okay dipsh!t, .
You asked a simple question, were told numerous times why your theory was illogical and still ignored this evidence and asked for data. Asking for data for something that is illogical is moronic. As I have said twice, it is likely that there is a slightly higher chance of an automatic transmission equipped vehicle igniting but not because of your moronic theory. It is because of the relatively flimsy transmission oil lines that run between the gearbox and oil cooler.
eleison
1,319
Okay dipsh!t, .
please tell me which of the following statements are incorrect/moronic:
1) a turning/working motor in a crash will increase the probability of a fire.
2) before an accident even happens, if a person steps on a break with the car in gear (obviouisly this car is a manual), there is a better chance the motor will die/stall before impact or before flipping over when compared it to an automatic.
3) even after a point of impact, an automatic car's motor has a higher chance of turning then a manual especial if it's wheels are on the ground and not moving.
4) a car which has its motor not turning.. it is producing less electricity, hence the probability for a car fire is lower -- regardless if its standing still or in an accident, etc.
clickynext
2,583
Sigh... it's a shame they died. Sounds like the idiot had more power than he knew how to control. And his drive wheels were on the wrong end of the car.
iamaelephant
3,816
Okay dipsh!t, .
As Zenmervolt and I have been trying to tell you, the bolded part is incorrect. Fires are caused by hot components, NOT by running engines. Everything that produces a spark or naked flame is INSIDE the engine, and an exhaust manifold, turbocharger or catalytic converter will stay hot enough to ignite fuel for several minutes after the engine has been stopped. There is also a major flaw in your understanding of electrical systems but to be honest I don't think you're even bothering to read my posts so I can't be bothered explaining it to you.
herbiehancock
789
Pretty much all of them, actually.
1. As has been told to you time and again, but obviously you've chosen not to listen at all, the engine running or not doesn't increase the possibility of a fire. Ask yourself......what needs to be there to cause flame. Ignition source, fuel, and air. The only fuel is the gasoline primarily but I suppose the auto. trans. fluid could be in rare cases. Air, given as it's all around us. Ignition source.....a running engine is NOT an ignition source, contrary to your twisted logic. The ignition source you keep trying to envision is INSIDE the engine.....the spark plug.
So, what can cause flames on the outside of the engine. Hot metal, such as exhaust manifold, catalytic converter, or electrical sparks. All of these sources exist whether an engine is connected to an automatic or a manual. NO DIFFERENCE!
2. Why? I suppose if you're an inexperienced driver with a manual, all you might do is jam the brakes on and hold on for dear life. I've driven both autos and manuals during my almost 40 years of driving experience, and although I've only had a couple of accidents.....and those were decades ago.....when I hit the brakes in a manual shifted car, I also pushed in the clutch pedal with my left foot.
Why? Because I wasn't just clutching my steering wheel and locking my brakes up hoping I wouldn't hit something like a moron or an idiot.....I was actively trying my best to get out of the situation if at all possible.....which meant brakes on but short of locked, clutch in, shifting down and even trying to steer out of it. I didn't want the engine to die because that would cause a complete loss of control of the car....no power, no steering, no ability to move.
3. Maybe true.....if the impact is in the side or in the rear.....but head-on, and you lose your engine, auto or manual. Your engine cannot run with its grille and radiator jammed into the engine bay.
4. That's idiotic. The key is still on and even if it wasn't....the BATTERY is still charged and powering all those lovely little wires under the hood with 12V. The exact same amount of electricity is present under the hood of a running car and a non-running car.....12V. True, the alternator is not turning on a non-running car, but that's not the major source of the electricity under the hood of a car.....it's the battery. So, unless the battery is removed completely from the vehicle just before you run into something, the fact the engine is running or not has no bearing upon the electricity present under the hood.
The battery holds a very large charge in it......a lot of amperage behind those 12V. Hitting something with the front of the car, auto or manual, will most likely expose wiring that is connected to your battery.....immaterial of whether your key is on or not or the engine is running or not.
You do understand that the big red cable that runs off your battery goes to several places under your hood, right? The largest runs to your starter.....and it's typically quite exposed to being damaged in a frontal collision. Of course, if the battery breaks loose from its underhood mounting, which again is a very real probability in a frontal collision, just touching the positive terminal to any metal on the car completes a circuit and causes a spark.
So, the real ignition sources under the hood are from broken wiring and/or battery and from hot metal such as exhaust manifold, exhaust pipe and catalytic converter. The engine running has nothing to do with any of that......all the exhaust components are already hot so the engine doesn't have to run to have them stay hot. The electrical component of ignition for fire is from the battery, not your mistaken belief of the alternator having to run.
But, this is all silly.....in a frontal collision, the engine dies......manual or automatic. In a rear-end collision, it's immaterial if the engine is running or not....the fuel source is in the rear and any spark from the front cannot leap 15 feet through the air to the rear of your car from under your hood.
Like has been pointed out before........this is an idiotic belief you hold. To each his own....but please keep everyone informed here of when you get on the road so we can get off it. I don't want to be within 10 miles of you when you're driving if you cannot do anything but skid into another car instead of trying to maneuver out of an accident. If you cannot do that, you're no better than a 90 year old great-grandmother who points and hopes for the best.
skace
14,488
7
How fvcking bad of a driver do you have to be for this to actually be a concern of yours when purchasing a car.
sonoma1993
3,414
21
I think the op must be a very bad driver or very paranoid
Aug 23, 2000
15,509
I was thinking if I was driving a automatic and if I got into a crash, if the engine is in somewhat a "good shape", it could still be "working" causing a fire.. however, if a person is driving a manual, if he got into an accident, his car would lock up the tires and the motor would not be working anymore... no spark.. less likely to cause a fire...
That is a good point.
Not really, fires are usually caused by a fuel leak, (that's why fuel pumps these days shut off when the airbags go on), and if there is a fuel leak something is going to spark.
Damn, you replied as I was editing my post. You're too quick.
thanks for the info... need to do more research. In my first accident, my airbags did not go off (the car was totaled).. in the 2nd, my side airbags went off but not my front. In both cases, a lot of fuild leaked, but the engine was not turning anymore (my cars were both manuals).
Personally, I think that if theres a fuel leak, automatics will naturally be more apt to catch fire while manuals would not. Having a "turning" motor when there is a fuel leak is a lot more dangerous then have a "dead" motor.
The engine doesn't have to be on for it to cause a fire. Ford and Saturns have had electrical problems causing fires on cares that were not even in use. And the cause for most fires is fuel lines rupturing and spilling on exhaust manifolds which can be red hot. Even if the engine turns off the exhaust manifolds are still going to be hot for a while.
eleison
1,319
Fuel leaks are not usually the cause of fires. Only 13% of car fires are caused by a leak or break. Sixty-five percent of the highway vehicle fires began in the engine, running gear, or wheel area which is far from the fuel tank..
http://www.nfpa.org/publicJournalDetail.asp?categoryID=&itemID=32341******=NFPAJournal
replace: ******=NFPAJournal with &src=NFPAJournal
I agree with the fact that an engine doesn't have to be on for it to cause a fire. However, being on will increase the probability of a fire.
"Additional and more in-depth fire testing of automobiles and other vehicles can increase our knowledge of how these fires develop. This detailed information can provide engineers with the information needed to develop solutions to the automobile fire death problem (similar to the advances, such as the airbag, that have resulted from collision testing)."
in addition, with the small amount of research that I have done, everyone basically agrees that a "dead engine" is a good thing with respect to car fires:
"Turn off the ignition (which kills the engine) to shut off the electric current and stop the flow of gasoline"
Link
"Nearly three-quarters of accidental car fires are due to vehicle defects, with defects in
wiring and batteries being the biggest single cause. Only 7% of accidental car fires are
caused by a crash or collision."
Link
http://www.communities.gov.uk/pub/894/F...itedKingdom2003PDF1724Kb_id1124894.pdf
I would presume having the engine off will cut off a lot of electricity to the car... greatly reducting chances of a fire..
sao123
12,656
206
Link
Way to skew the statistics...
:roll::roll::roll::roll::roll:
From your own links:
Contributing factors
Most highway vehicle fires result from either mechanical or electrical problems, while collisions or overturns were factors in only 3 percent. Collisions or overturns, however, caused 58 percent of the associated deaths.
According to the report, mechanical or electrical failures or malfunctions caused almost three-quarters of the highway vehicle fires, but 9 percent of the deaths. Collisions or overturns were factors contributing to the ignition in 3 percent of the fires , but fires resulting from these incidents caused 58 percent of these vehicle fire deaths. Sixty-five percent of the highway vehicle fires began in the engine, running gear, or wheel area.
This 65% is all fires, not those in collisions. There is no established relationship here. Your car is 25 times more likely to suffer a vehicle fire from faulty wiring or switch, than from a crash.
From your third link...
See highlighted comment above
Earlier this year, NHTSA ordered the recall of 6.7 millon Ford vehicles because federal investigators concluded that the cruise control switch might cause a potentially devastating fire that could spread throughout the engine compartment and set the vehicle ablaze.
At least six flammable fluids under a car's hood can leak onto hot surfaces and start a fire so AAA suggests fluid lines, hoses, caps and filters be inspected and maintained to prevent leaks.
No Running vs NonRunning Difference here
[*] If possible, pull to the side of the road and turn off the ignition. Pulling to the side makes it possible for everyone to get out of the vehicle safely. Turn off the ignition to shut off the electric current and stop the flow of gasoline. Put the vehicle in park or set the emergency brake; you don't want the vehicle to move after your leave it.
Turning off the ignition does not kill the current in the vehicle, only to the engine. Your coolant fan, interior lights, brakes, brake lights, headlights, and 12volt power socket all work with the ignition off.
There is no evidence to substanciate your claim that a fire is more likely with the engine running, than with it turned off.
If you want something to predict as a future spark trap for vehicle fires, wait till all these hybrids start having significant number of accidents... then when the batteries start leaking, exploding or catching fire... we will see how safe they are in accidents.
Evadman
Administrator Emeritus<br>Elite Member
Feb 18, 2001
30,990
Err... what?
WHAT?!
<sigh>
First, check your sarcasm meter and read the whole post, not just the part that you feel like. Second, every one of those stupid examples I gave have a low, but non-zero chance of happening, which makes them possible but improbable like I said in the fricking post if you read the damn thing.
a flywheel can break with any force, which is why in drag racing you need a shield on your transmission when running faster than a certain ET. The flywheel can explode at any time from the smallest of defects,a nd slamming into a non-moving (or slow moving) object can cause that minor defect to turn into a crack, which if in the right place can cause the flywheel to tear itself apart. since the flywheel is right next to your feet in a lot of RWD cars, that means your legs can be in the way.
The flywheel can come apart in well under a single rotation. But once it comes apart the pieces are not going to stop until their kenetic energy is absorbed. The engine will stop moving with the frame of the car, but it will still be turning over until the grille, bumper, or other piece of the car jam into the crank, or other rotationg part of the engine thus slowing the engine through friction. Of course something can hit it just right to stop the engine all at once, then the deceleration of the motor (several hundred or perhaps thousands of G's) can also cause the flywheel to come apart which would do exactly the same thing. The cracking and piercing of the floor and other material will heat the fragment depending on the speed of entry and exit though said material. It may not be white hot, but it can exceed the ignition point of wood and start a fire. Again, we are not going for likely, this is supposed to be unlikely per my fricking post!
Of course, you knew all that already being a ASE certified technician right?
jagec
24,442
1) If the fuel pump shuts off; if you get into an accident, why would your fuel pump shut off? Remember sometimes airbags don't go off when they have to. Also, driving an automatic, you can go from 60-0 (basically to stop) using your brakes very quickly, but your engine still "turns" at the end. In a manual, your engine stops if you go from 60 to stop.
2) getting into an accident, wouldn't that likely damage your "cut-off" circuits causing them to fail?
I don't know about you, but I usually push down on my clutch when I'm going from 60-0, thus my engine is still running at the end:p I get your point, though.
It's very, very unlikely that a crash would damage the cutoff circuit enough to cause it to fail, while leaving all the electrical and mechanical components necessary to keep the engine running intact.
Fuel leaks don't just occur at the gas tank, you know, in fact a LOT of them occur in the engine bay, where there are piles of fuel lines running every which way, surrounded by hot, sharp bits of moving metal.
Again, there's a huge difference between an engine which died because it was TURNED OFF (unlikely at the moment of an accident) and one which stalled because of wheel lockup.
Having the ignition switch off does reduce the chance of a fire, even though there is still a fair chance if there's a leak of any flammable liquid, or damage to any of the wiring.
Its weird.. A lot of people seem to not be able to think "out of the box"... they always have to believe what they are told without research or data to back them up. Please, if I am wrong.. give me some links... Automatics are cool... Whenever, I have a girlfriend, they always want to drive my car, but they couldn't because it was a manual. thinking about buying a automatic for my next car... but, if people cannot cannot show me proof that they are as safe as manuals, I'll probably be buying a manual.
Thinking out of the box is not the problem here. It's just that you can't go from the first step (coming up with unconventional ideas) to the second step (deciding if the evidence shows any truth to them).
iamaelephant
3,816
I don't know what ASE is but I'm a qualified mechanic and I know my stuff about cars and I know what you said is nothing but gibberish and purple prose. This is why I stay away from ATOT car threads in general, too many stupid people who think they aren't stupid.
Edit - I just looked up the ASE and yes, I have the NZ equivalent of that qualification.
jagec
24,442
Dude...ever hear of hyperbole? I'd have thought that the orphanage bit would have been a tipoff, if nothing else.
Raduque
13,140
138
What kind of manual car driving idiot is going to jam on the brakes like they were driving an automatic? Even if a manual driver is going to slam on the brakes like that, their left foot is still going to be hitting the clutch.
foghorn67
11,883
63
MOST cars sold in the past umpteenth years have automatic transmissions. Of course there will be more wrecks with cars with automatic transmissions.
wetcat007
3,502
They were racing a Honda Civic and Mazda RX8? Seriously you don't need a race to know who's going to win that battle. Young irresponsible people + sports cars=death
It's a well known fact and unfortunately continues to hold true..
