- Mar 8, 2003
- 38,416
- 4
- 0
Thanks for the testing.
Looks like you had several false positives... may have to turn down Sophos' heuristics or just remove it completely.
I really think that the aVast (note the one used in the script is NOT the full version) and the Microsoft Malicious Software Removal tools are useless in this, as the other programs should catch their limited library of malware.
I just wish that I could get the antivir command line version working, but I think that it is a 16-bit application.
It was not supposed to, the only I way that I could make it unattended was to fully purge any progress bar.t the Microsoft scanner never showed a log or progress bar or anything to see what it was doing.
Yeh, this thing is mainly for starting on a room of like 50 PCs and letting them run overnight. I am getting the same feedback from the people that are field testing about scan time. I may create a "light edition" with only a2, Trend, and Mcafee or something similar. It is already easy to remove certain scanners yourself (just remove the entries in the .cmd file within scanners).the entire test ran about almost 9hours and again i stopped early. the test had no interruptions for the most part damn thats long time haha.
