GSkill value RAM is the same as the GSkill Ripjaws. Only difference is the 100% useless heatsinks.
But they're RED!
I just noticed this thread today, but I think you'll be pleased. The only I'd have changed is the RAM - Autodesk recommends the fastest RAM you can get because it's highly computation intensive. The i7-2600 is perfect; as Autodesk's multi-threading is for shit, it's extremely sensitive to clock speed and memory bandwidth, and the second generation turbo boost will be great. Incidentally the AMD Phenom IIs run AutoCAD astoundingly well, although the Intel chips are still my preference. You spend a couple hundred more, but EVERYTHING runs fast, not just AutoCAD, and sooner or later, when Autodesk manages to really multi-thread, the Sandy Bridge will pay off.Ordered 20 May:
MSI P67A-GD65 (B3) LGA 1155 Intel P67 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
Intel Core i7-2600 Sandy Bridge 3.4GHz (3.8GHz Turbo Boost) LGA 1155 95W Quad-Core
2x G.SKILL Ripjaws Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666)
PNY VCQ600-PB Quadro 600 1GB 128-bit DDR3 PCI Express 2.0 x16
Intel 320 Series SSDSA2CW120G3K5 2.5" 120GB SATA II MLC
CORSAIR Enthusiast Series CMPSU-650TX
Intel PWLA8391GT 10/ 100/ 1000Mbps PCI PRO/1000 GT
ASUS DRW-24B1ST/BLK/B/AS Black SATA 24X DVD Burner
Microsoft Windows 7 Professional SP1 64-bit
Antec Three Hundred
LITE-ON SK-1788/BS 2-Tone PS/2 KB
RAZER DeathAdder
2x ASUS VW246H Glossy Black 24" 2ms monitor
and this: http://www.amazon.com/gp/product/B002R9HQLI
I opted in for Shop Runner and their free 2 day shipping. Everything is due the 24th. I'll probably end up keeping the Shop Runner subscription as much as I shop there. We'll see. Amazon and Newegg generally have the same price. amzn orders have tax added, but I get 3% rebates and free 2 day shipping with Prime eligible orders. Without Shop Runner, NE has no tax, but has slower shipping and only 1% rebate using my Chase rewards card.
Like I stated, we'll see if I keep it after the 30 day trial.
Can't wait to get the anti-static wrist strap out and get to work!
I just switched to AutoCAD MEP 2011 on my i7-870, and I'll say one thing. Every version of AutoCAD runs better than the next. (Well, except for 9, 14, and 2000.)
Everything arrived, and I managed to stay at band rehearsal while the parts just sat there in the living room...
I followed the assembly order listed on the mobo's quick start guide, but was surprised by how shitty the cpu cooler attachment system is. Seriously, that thing is horrible. In fact, I did it wrong the first time so the system would start, then run for five seconds and shut down. Rinse, repeat. I disconnected it, then reconnected and all is good. Maybe it's the stock cooler, but I sure prefer AMD's mounting option.
Downloaded the new v4.2 of memtest+86 that supports SB. Test is running now. 42% complete after 21 minutes.
Pushpins do suck. I usually install the CPU and HSF first (mobo outside of the case) so that I can look at the bottom of the mobo and see whether not they're fully engaged.
So it must be running windows at this point?
You're making an assumption there.
Please note: I have support contracts with Autodesk. One of the first questions they ask me is: Which Certified graphics card are you using and which certified driver version?
