Hey there, need some help/advice. I have ended up with too many devices and need to figure out how to handle them all.
I have this receiver (2 HDMI in one out and 1 optical out): http://usa.yamaha.com/products/audio-visual/av-receivers-amps/htr/htr-6230_black__u/?mode=model
This Blu-ray Player: http://shop.panasonic.com/shop/model/DMP-BDT220
And we now have an Xbox 360 Kinect set-up for the wife, which is causing the issue.
Questions:
1. Since I only have two HDMI inputs on the receiver, is there an easy way to either route the HDMI of one device through one of the others or two quickly switch between them?
2. I was under the impression that HDMI can do both audio and video at the same time, but I can't seem to get any sound unless I use the optical cord. This means I can only have one of these two devices plugged in at a time, which is a huge hassle because it's far more annoying to blindly switch an optical cord than an HDMI cord. Am I doing something wrong here, or am I misunderstanding how this works?
Hopefully that's all that is needed.
Thanks!
KT
Questions:
Thanks!
KT
