I bought a awsome bottom of the line Enermax case for 49 bux. It is so crappy even though it is a enermax brand case the crappy 350 PSU isn't even a enermax.
Well here comes my question it didn't have any instructions on how to hook up the two usb ports from the front of the case to the motherbord or the audio in, and audio out jack. Well I figured out the USB by trial and error and it works fine. But I can't figure out what to do with the audio In or Out jack.
The computer just has two header wires for the audio in and one is labled ground and the other has no label. And the mic jack is just one header wire.
So.... does anyone know how to connect it to the audigy I have using the unused internal pins on the card that were meant to be connected to the audigy front bracket connector thing.
Or.... where I can buy a wire/connector that will allow me to connect it to the outside of my audio card like you would normally hook up a mic/speakers?
Thanks Much I haven't found anything out on the audigy board pins, and was wondering if anyone knew about them.
