Hrm.. didn't see any of that expanding foam at home depot. Also, if I were to use batts, wouldn't it be pretty useless too since it's still getting compressed?Originally posted by: AlienCraft
3. Seriously speaking, that compressed fibreglass batt under the storage floor decking is practically useless. Better to pull it out and put a proper batt under there or best idea remove and spray in the high R value expanding foam. That way all voids are filled and that stuff exceeds an R15 3" batt like 3X.
6. Got an asphalt shingle roof? Been more than 5 years up there? Then it's time to re apply the white granular pebbles that have been blown off over time. These granuals are available in bags and you reapply them like sowing seed over a warm roof. There is also a compound you can apply to get some more "stick" to the roof.
Simply making the surface more reflective via the granuales white color can reduce interior temps.
as for #6... I have this issue with climbing on the roof... (and ditto w/ the siding job DrPizza, heh). I also have no idea what is on there, but I assume it's asphalt type.
And home depot is so useless.. no one could tell me how I would go about getting the cellulose insulation and details for how much I'd need to buy to get a free rental for the blower.
