- Dec 11, 1999
- 16,695
- 4,658
- 75
Yeah, kind of, at least for now. I'm not sure what to do with video card prices inflated by mining.Did this thread die?
Damn I must be out of touch.Yeah, kind of, at least for now. I'm not sure what to do with video card prices inflated by mining.
Yeah but that was replaced by ASIC devices while other coins still use GPUs for mining.Damn I must be out of touch.
I didnt know video card bitcoin mining was a thing until just now.
Indeed. I'm waiting for the bubble to burst myself.Well there's a bunch of hoodoo involved as well, also speculators & thieves.
Correct me if I'm wrong, but I thought you only needed DDR4-3200 if you are planning on overclocking? wouldn't 2666 be fine for sticking with stock speeds?RAM prices as well as high GPU prices have put a serious crimp in the budget, I think. For those who have to have a faster video card, several sacrifices would have to be made, like going down to 8GB RAM, going to a Ryzen 1600 with its included Wraith Spire cooler, and using a cheaper SSD. Thankfully the selected AB350M has 4 RAM slots, so it would not be hard to go to 16GB later, though it would be less cost effective:
https://pcpartpicker.com/user/crashtech/saved/#view=YHM3FT
Really it seems with prices the way they are, even with AMD being a better competitor, the budget for an effective midrange machine should probably be $1200 now, that would allow for 16GB and a 1070 easily.
All AMD CPUs are unlocked, and the stock cooler will allow for a mild OC, so I just stuck to RAM that didn't deviate too far from Ken's build. The listed set was actually cheaper than some other DDR4-3000, which is what Ken's build used. I suppose my assumption was that a better cooler could be added later as well, that's what my son eventually did with his Ryzen rig. I think RAM OCing in particularcan really help gaming performance with Ryzen.Correct me if I'm wrong, but I thought you only needed DDR4-3200 if you are planning on overclocking? wouldn't 2666 be fine for sticking with stock speeds?
Yeah I hear you, but if I was doing a new build with either Ryzen or Coffee Lake I would go with DDR4-2666 memory as I won't be overclocking since I prefer stability and longer lifespan of equipment. I'm on a fixed income.All AMD CPUs are unlocked, and the stock cooler will allow for a mild OC, so I just stuck to RAM that didn't deviate too far from Ken's build. The listed set was actually cheaper than some other DDR4-3000, which is what Ken's build used. I suppose my assumption was that a better cooler could be added later as well, that's what my son eventually did with his Ryzen rig. I think RAM OCing in particularcan really help gaming performance with Ryzen.
That's the great thing about building PC's, they are fully customizable! I think these builds that Ken posts could be seen as a starting point, not everyone has the same needs. For instance, many users will have a HDD out of another machine that could be used as bulk storage, freeing up that money for a bigger/better SSD or anything else that's desired.Yeah I hear you, but if I was doing a new build with either Ryzen or Coffee Lake I would go with DDR4-2666 memory as I won't be overclocking since I prefer stability and longer lifespan of equipment. I'm on a fixed income.
Well I thought about upgrading from a Haswell i5 to a 6 core CPU and reuse the rest of my current rig, but I really don't want to spend ~$400 or more to do it.That's the great thing about building PC's, they are fully customizable! I think these builds that Ken posts could be seen as a starting point, not everyone has the same needs. For instance, many users will have a HDD out of another machine that could be used as bulk storage, freeing up that money for a bigger/better SSD or anything else that's desired.
I don't think a Ryzen 1600 would be that much of an upgrade from a Haswell i5, depending on what you are doing. Presuming you wouldn't mind a used CPU, a 4770 might be a good upgrade option for you, or even one of the many 8 thread Xeon E3 models if your motherboard supports it. Note that the one I linked requires discrete graphics.Well I thought about upgrading from a Haswell i5 to a 6 core CPU and reuse the rest of my current rig, but I really don't want to spend ~$400 or more to do it.
Well I do have a GTX 970 installed. call me after the 1070 drops to $250 or less. That is most likely the upgrade I would see the most benefit from anyway.I don't think a Ryzen 1600 would be that much of an upgrade from a Haswell i5, depending on what you are doing. Presuming you wouldn't mind a used CPU, a 4770 might be a good upgrade option for you, or even one of the many 8 thread Xeon E3 models if your motherboard supports it. Note that the one I linked requires discrete graphics.
Value in hardware has gotten harder to find.Damn shame about this thread. Nothing quite like it and it was always the "goto" spot for any of my builds.
Well the 2200G and 2400G does bring some value back at the low end at least.Value in hardware has gotten harder to find.![]()
If only mobo compatibility with those APUs wasn't such an issue. Maybe it will be worked out in the next few months. (ASrock AB350M Pro4 UEFI/BIOS, I'm looking at you!)Well the 2200G and 2400G does bring some value back at the low end at least.
Yeah we will have to probably wait until the 400 series of chipsets come out.If only mobo compatibility with those APUs wasn't such an issue. Maybe it will be worked out in the next few months. (ASrock AB350M Pro4 UEFI/BIOS, I'm looking at you!)
