ATTENTION ASUS
Originally posted by: BTRY B 529th FA BN
Originally posted by: Zap
Originally posted by: Texun
I have no issues with their boards but the website has been unacceptably slow for as long as I can remember.
Back then they ran it off a 14.4k modem. These days their bandwidth is the home DSL connection of the son of one of their engineers. When you get a "page not found" that means the kid is running a torrent. :roll:
are you serious?
What do you think? [/shiftyeyes]
are you serious?
very believable :laugh:
Originally posted by: harbin
Just playing with my first ASUS motherboard, I can't say i am impressed at all with P6T D V2 due to infrequent BIOS update and a couple of issues here and there with the highly hyped "ASUS quality".
Your logic is right, but I don't have a stability problem. I want 2 things on V2:
1. working Sleep mode with Bclck >=195
2. Enable Turbo while Speedstep is disabled
Asus is not updating BIOS to address this SM issue while other MB manufacturers are working towards correcting it with newer BIOS.
They have addressed this SM issue on the P6T and the P6T deluxe
"P6T 0502 Bios/P6T deluxe Bios 1403"
"Fix system may not able to resume from S3 if Base Clock is set over 170MHz"
The P6T has had 5 bioses and the P6T deluxe has had 8 bioses. The V2 has only 2 but remember the V2 was released later than the others so i'm sure you will get the bios update soon for this issue.
The other issue might not be able to be done, it might be an Intel spec thing. I dont know if other board makers have done it but anyway you might do what i did and leave speedstep enabled in the bios and turn it off in the OS power options. That way the speedstep is effectively disabled with turbo on.
Theres a problem having turbo on at high overclocks (around 200 Bclck) but i'm sure its the same with other brands of motherboard.
Anyway your board is very new and i'm sure there are bios updates to come.
Heh, it seems like it. 🙂
27 minutes to update the Asus P5N-D motherboard BIOS is cruel.
And always that "What OS?" popup when you are looking for drivers.
