Think of it as a fan that's blowing 4PSI by itself, regardless of what the input pressure is (of course less than 4PSI). In this case, the input pressure is already 4 PSI.
I'm just trying to make a point.
but then...why do people do push pull on heatsinks?
LOL, would you guys be happier if I said "compressor"? Look at the quality of the artwork, thanks care.
That's for you to figure out. It's not that complex, simple pressures logic, really.So its at 4 psi then its "compressing" it to 4 psi?
It could be a genie that pushes out 4 PSI with his flatulence, same difference.
Right, and the earliest people that replied didn't have any problems with the concept either.This may end up wrapped in semantics, and technical details, but if that's a compressor, compressing at 4psi, then it's 4psi coming out. It would be compressing nothing since the regulator would keep the 4psi pressure on both sides.
It's elementary physics.This is regarding a thread in the garage about an engine with a couple turbos feeding a supercharger. A good chunk of the posters are convinced that the intake manifold wouldn't see turbo pressure differential + supercharger pressure differential above atmosphere.
He was arguing that if a turbo that puts out 15PSI and a supercharger that puts out 15PSI into an intake you'll see 30PSI at the manifold...A supercharger is positive displacement. If the turbos can produce enough FLOW to increase the input pressure on its suction side then there will be a higher pressure on its discharge side and an increase in MAP. Why anyone would want to do this is beyond me especially when you can cascade blowers.![]()
Did you ever notice that PSI sounds like a leaking tire? Psiiiiiiiii......
I've done virtually nothing with fluid mechanics in 20 years, so I'm very rusty. But I keep coming back to Bernoulli. If you go from a higher volume to a lower volume, velocity increases in the narrower pipe. But, contrary to "common sense", the pressure actually decreases. (Or am I getting this principle mixed up - been 20+ years.) Also, I was thinking in terms of liquids, not air.
the whole point of a compressor is to increase pressure at the cost of adding heat. if the pressure is the same on both sides of the compressor, then it isn't doing any work, if i'm not mistaken.
That's silly. I'm just a dummy, and I know better :^D
