These T-SKUs in the slides have a TDP of 4W according to Intel.
- The SPECspeed® metrics (e.g., the SPECint® 2006 benchmark) are used for comparing the ability of a computer to complete single tasks.
- The SPECrate® metrics (e.g., the SPECint®_rate 2006 benchmark) measure the throughput or rate of a machine carrying out a number of tasks.
not all a72 deliver that kind of perfomance, check sd650Closer but not at A72 level yet: https://browser.primatelabs.com/geekbench3/compare/6064783?baseline=7352874
I guess that it s the same kind of "TDP" as cherry trail s, 6W officialy but measured at more than 10W by hardware.fr who stated that the TDP is underestimated...
And most likely not all Goldmont will deliver the same performance that was quotednot all a72 deliver that kind of perfomance, check sd650
https://browser.primatelabs.com/geekbench3/7878018
That is a mid-ranged SOC manufactured in 28nm and clocked at 1'8GHz, so it is not a fair comparison.not all a72 deliver that kind of perfomance, check sd650
II guess that it s the same kind of "TDP" as cherry trail s, 6W officialy but measured at more than 10W by hardware.fr who stated that the TDP is underestimated...
You sure? The Atom in my Surface3 didn't feel that much slower (in CPU tasks) than the 6Y30 in my Spectre x2.Not even close.
Human subjective perceptions is not the best way to objectively measure things.You sure? The Atom in my Surface3 didn't feel that much slower (in CPU tasks) than the 6Y30 in my Spectre x2.
However, we tested the sample with a single-core benchmark, Cinebench R11.5 (0.54 vs 0.4 in favor of the N4200, of course), and compared it to the N3700. The Apollo Lake chip scored 35% better than its Braswell counterpart even though it has considerably lower clock speeds. This seems promising and we suspect that the final unit will deliver even higher performance, especially in the multi-core tests./quote]
http://laptopmedia.com/news/intels-...entium-n3700-by-35-in-single-core-performancel
something with near the performance of a 65nm Core 2 Quad on the power budget of a night light isn't a bad thing.
In comparing the mobile Pentium N4200 versus the most powerful mobile Braswell SOC, the Pentium N3710, Intel is promoting that the N4200 is 30% faster in SYSmark 2014. Meanwhile they’re reporting that the same setup is 45% faster with 3DMark Skydiver.
On the CPU side, keeping in mind that the two chips have a maximum turbo clock within 60MHz of each other, the performance gains are significant. While it’s unclear if Intel keep memory bandwidth the same (Apollo Lake supports LPDDR4, Braswell does not), it either way hints that the Goldmont CPU core offers significantly higher IPC than the older Airmont CPU core. This is only one test – and from the manufacturer at that – but it will be interesting to see how well other benchmarks respond to Goldmont once we get our hands on Apollo Lake devices. At the same time, for performance to increase by 30% despite the much lower CPU base clock, this indicates that Intel is likely still coming out well ahead even if they had to pull back on frequencies a bit due to power consumption.
As for the iGPU performance, a 45% increase is a combination of factors. Just by the raw numbers, the Apollo Lake Pentium has a 20% GPU throughput advantage due to its higher GPU turbo frequency and overall wider GPU configuration. At the same time this accounts for less half of the reported performance increase Intel is reporting. So we are also seeing the overall performance and efficiency improvements of the Gen9 GPU architecture in action.
