Arkaign
- Oct 27, 2006
- 20,736
- 1,379
- 126
I did Atkins, so did my brother, it really does work, but you 110% have to stick to it. I don't believe it's all that healthy, but holy crap it works fast. If you cut your carbs to say less than 5 daily, you can lose 30-40lbs in 4-6 weeks easily. You do sort of feel like crap on the diet though.
It's not bad for a short-term weight fix, then you can start to work out more (hard to work out for some overweight people, as it's hard on the joints if your body isn't used to carrying extra weight), and start transitioning to a healthy balanced diet.
Rule #1 of any diet should be : avoid excess sugar and excess simple carbs.
