rahulprabhu
Hi All,
Some 3-4 months back I bought an ATI Radeon 9800 Pro Card. But since then life has been miserable. In normal circumstances the
PC works perfectly fine. But as soon as I start playing games (any of the
new games), after about an hour or two suddenly the Power Supply blows off
!!! This happened twice in the beginning and as it was the rainy season at
that time, I though that it might be causing it in some way... I know it
sounds silly (Moisture and all that nonsense as per the Hardware guy). When
it happened for the third time, the power supply took the Processor and
Motherboard along with it. After putting in lot of efforts, I somehow
managed to claim the warranty for both and luckily I got a new Processor
and Motherboard.
This time I used a 400W Power Supply of Company - IBOX, but yesterday
even that blew off while playing FAR CRY. This keeps happening with me
whenever I play games. I am tired of getting new Power Supplies everytime.
What do think the problem might be ??? I know that it has something to do
with the Graphic Card and Games for sure... isnt it?? Can there be some
leakage of current in the Graphic Card or something ??? If that was the
case then the computer shouldnt have started at all right ?? I dont think
it would have waited for 2-3 hours to burn if there was some problem.
Do ATI Cards have this problem ??? Do you think 400W Power Supply
is not good enough ??? but even if it was less, should it blow off ??
My ATI Card does require a direct connection to the Power Supply for the FAN. Does this have anything to do with the Power Supply blowing off.
Please let me know ASAP on what you feel about this whole issue and what
I should do ....
and Motherboard.
I should do ....
