ATI 9800np with Samsung Memory, same as 9800 PRO?
mcmeekan
I must be the lucky one to actually purchase an ATI 9800np (at a local Best Buy in NJ) and actually get Samsung memory chips, now I need someone to tell me if this is the same memory as the 9800 PRO. This is what the memory saves:
SAMSUNG 319
K4026323RA-GC2A
Should I updated the BIOS or simply increase to Core and Memory speed to 9800 PRO specs? Thanks in advance.
-jm
GullyFoyle
4,362
11
That's the 2.8ns stuff.
You could probably get to Pro without flashing, you might be able to go farther past Pro with the BIOS (because of the extra voltage).
Of course if you don't flash, you avoid the risk of screwing something up.
jiffylube1024
7,430
SAMSUNG 319
K4026323RA-GC2A
-jm
Yep, that's the one. Pro-spec'ed memory and all. You should fly past 350MHz memory speeds, you lucky bastard ;)!
<-- Grumpy guy who got one with Samsung GC33 chips.
wnied
4,206
Where did you buy your card from, and when you do decide to OC let us know how you make out...
~wnied~
Lanyap
8,286
2,381
Anybody know what this 9800np Samsung is: K40263238E-6C33
Is this the 3.3ns?
Skitzer
4,414
Yes, that has the good 2.8ns Samsung memory. I'd flash to a 9800 Pro and then overclock the hell out of it to see where the sweet spot is! You got lucky.
Robor
Is this the 3.3ns?
I've got the same memory... I flashed and am running 400 core 350 memory. No problems at all.
tech
156
question, does your ATI 9800np from BB say ATI 9800 pro on the serial sticker in the back of the card. Thanks
