trabpukcip
- Jun 22, 2005
- 17
- 0
- 0
I have an old machine with a 9800 pro and nForce3 150, the reason why you can't set AGP 8x is because your AGP Driver is not installed. I had to manually install the chipset drivers piece by piece to get everything working ie. right click on each .inf file in the driver package.
That should fix that problem because the card is not even working at AGP 4x this way it would be working at PCI speeds which is not always noticeable but can cause a lot of stutter and lower performance. I had this problem a year ago and the nVidia Chipset driver package wouldn't install on its own, so thats when I was forced to do it piece by piece which worked.
Also make sure your bios is set to AGP 8x.
Once you have done all that the SmartGART should be set to 8x and performance should improve.
