scooterlibby
- Feb 28, 2009
- 752
- 0
- 0
GPU's aren't really good for gaming. They do not help nearly as much as an SSD would. You should see at least a 74% boost in FPS with a new SSD.
Intel makes the best SSDs, and AMD makes the best GPUs.
I vote for a 5870 and 160GB SSD.
My motherboard will do crossfire, and my PSU is a Corsair 850TX.
hawtdawg said:Yep, SSD all the way. A 5970 might even lower your gaming performance due to it being 2 GPU's instead of one.
Is this true -or is scooterboy having a laugh? I can't see how this would be so please explain
The OP has a HD4870x2... those are 2 GPUs on one card...
Seriously, do you guys read the first post at all?
You took those posts seriously?
The OP asked a question. You answered. You have 6 posts. Yes, I did take your reply seriously. Not to mention other people clearly didn't read the opening post and replied anyway.
Sarcasm, irony and jokes do not go well over writing. So next time when you want to joke about a recommendation, kindly mark it somehow.
As for the question, either get a HD5970 or a cheaper GTX480 (and slower). Your system already has a Core i7 and a SSD... the only thing that will give you more performance is a new GPU. Which one of those two? It's up to you to decide. Since a HD4870x2 is a bit faster than a HD5870, the difference going to a GTX480 will be not so great, if at all noticeable. If you're happy with your HD4870x2, you will be very happy with a HD5970, so in your position that's the choice I'd make. It is the fastest card available after all and is noticeably faster than a GTX480 (uses less power too!).
If you mean simply swapping one SSD for another, I agree, there is no benefit, but SSD's with it's low latency and high random reads in general have shown to improve texture streaming.
http://images.anandtech.com/graphs/intelx25mlaunch_090808151933/17331.png
Well as an owner of both I can tell you that the 480 plays smoother than the 5970. Forget the benchmarks. Nothing wrong with mine as the 5970 shows higher numbers but numbers aren't games, right? The 480 just moves smoother on the screen that is all.
That's no good, I just ordered a new 5970. Hopefully this gets fixed somehow.
Problem is if you look by benchmark numbers there is nothing to fix.![]()
It's purely for games, I've never benchmarked in my life. The 480 I tried made my room hotter, or I'd have kept it.
Strange, the 5970 I've used before wasn't as noticeable with heat. If I'm gaming at 1920x1200, is the 480 going to serve me better?
Hmm, now I'm torn. Since the stuttering issue is on my mind, I'm sure I'll be noticing it more. I like Nvidia/drivers/physx more, but the heat was my problem. If there's a way to reduce the "hot" feeling while sitting at my desk, I'd go back to a GTX 480 but I'd have to sell my Asus 5970.
