nemesismk2
Originally posted by: Zebo
Originally posted by: Duvie
In my opionion a 3000+ A64 is better then a 3.0 p4c in gaming and behind slightly in multimedia apps...Therefore for all intensive purposes looking at a whole think of a A64 speed as being equal to its p4c counterpart and not the P4e prescott...lets act like that one doesn't exist!!!!
With that in mind when it came to gaming and a majority of test the Barton 3200+ was not much faster then the Axthlon Xp 2800+ and thus is more comparative to a p4 2.8c...so maybe a 2800+ A64 if it exists....
In gaming it would be in that range in multimedia apps I tested it lost to my 2.4c at stock and usually got pounded by the 3.0c so it was somewhere between a 2.4c and 3.0c and closer to the 2.4c.....
Get it to a 2.4ghz and I think you have a p4c 3.0ghz/A64 3000+ range on a well rounded majority of things....
Duvie is basically right on. The AMD "ratings" went out the window with the dual channel C's came along then came back with AMD's A64.
The only point I'd disagree is the 400 "more" Mhz an XP needs to equal a A64/P4C 3000+... more like 250mhz more needed in most apps to equal it's rivals. Because the A-XP is even or better in apps high FPU like VB C++ compile/Sciencemark/LAME MP3 encoding/pifast/POV-Ray etc...
This link and the one linked above shows what I mean pretty well.. and even has the 2.4 barton in benchmarks which Duvie refers to for you all to compare.
http://techreport.com/reviews/2004q1/athlonxp-m-2500/index.x?pg=1
I don't think anyone would argue these little sub $100CPUs with a full 600MHz of overclocking headroom ar'nt the best bang for buck though...probably ever
Edit: link corrected
I agree 100% the athlon xp2500m has so much overclocking potential, I have mine running at 2.5Ghz using a voltage of v1.75 but I think it can go much higher with better cooling!
